Odd Parity Device and Hex Strings — Parallax Forums
T ChapT Chap Posts: 4,247
edited 2008-11-09 08:26 in Propeller 1
Hey guys. I just got a device in that uses odd parity.
Quite some time ago Mike mentioned that to communicate bi-directionally using odd parity, the ASM section of FDS would need tweaking.
Anyone know if there is an existing obj that has a switch on it to manage odd? I went through the whole list today of objects and don't see a description of anything that relates.
Ideally, I want to use the 4xport Full Duplex object to save cogs as there are other serial coms, but would settle for anything just to get testing right away.
8 bits, odd par, 1 stop, least sig bit first.
  • TimmooreTimmoore Posts: 1,031
    edited 2008-09-17 21:00
    Are you sure its 8bit odd par not 7 bit odd par? Often the parity is inplace of the 8th bit. If its 7 bit odd par you can fix it in the spin code by setting the most sign bit to the odd parity on tx and stripping the MSB on receive.
    If it is 8bit odd par then the PASM will need changing. The tx code sends 10 bits - 1start, 8 bits, 1 stop. If you want to take a look at moding 4port serial, you probably can't mod all the ports, there isn't enough cog memory left.
    This is the code you need to change. in particular txdata needs the 9th bit set to odd parity, before the shl instruction shown. This code is for the first port, similar code exists for each other port. Then change the last instruction to 12 bits.
                            rdbyte  txdata,txbuff_tail_ptr '{8}
                            add     tx_tail,#1
                            and     tx_tail,#$0F    wz
                            wrlong  tx_tail,tx_tail_ptr    '{8}
            if_z            mov     txbuff_tail_ptr,txbuff_ptr 'reset tail_ptr if we wrapped
            if_nz           add     txbuff_tail_ptr,#1    'otherwise add 1
                            jmpret  txcode,rxcode1
                            shl     txdata,#2
                            or      txdata,txbitor        'ready byte to transmit
                            mov     txbits,#11
    For the receive side
                            mov     rxbits,#9             'ready to receive byte
                            mov     rxcnt,bit4_ticks      '1/4 bits
                            add     rxcnt,cnt
    :bit                    add     rxcnt,bit_ticks       '1 bit period
    :wait                   jmpret  rxcode,txcode         'run a chuck of transmit code, then return
                            mov     t1,rxcnt              'check if bit receive period done
                            sub     t1,cnt
                            cmps    t1,#0           wc
            if_nc           jmp     #:wait
                            test    rxmask,ina      wc    'receive bit on rx pin
                            rcr     rxdata,#1
                            djnz    rxbits,#:bit          'get remaining bits
                            jmpret  rxcode,txcode         'run a chunk of transmit code, then return
                            shr     rxdata,#32-9          'justify and trim received byte
    Change the 9 in the first and last instruction to 10. This will not check partiy but just ignore it.
  • T ChapT Chap Posts: 4,247
    edited 2008-09-17 21:15
    Well the debug and testing app they supply as well as the docs all state the settings 8 bits, odd par, 1 stop.
    If you try to change the settings to even or none, the communication goes dead.
    I will try to make sense of the changes you pointed out, thanks for posting that.
    edited 2008-09-17 21:49
    You can do the parity piece completely outside of FullDuplexSerial since FDS just transmits whatever 8 bits you give it and receives 8 bits which it gives to you. You add the parity bit to the data being passed to FDS and check the parity on the received data as you get it from FDS. Admittedly, it's easier to let FDS do it since the assembly instructions can calculate the parity while there's no built in way to do it in Spin, but you can do it that way.
    PRI oddParity(X)
       return (((X << 1) ^ (X << 2) ^ (X  << 3) ^ (X << 4) ^ (X << 5) ^ (X << 6) ^ (X << 7)) & $80) | X
    To transmit oddParity do: ser.tx(oddParity(char))
    To check a received character for validity you can do: IF oddParity(char & $7F) == char
    edited 2008-09-17 21:50
    I think this is the odd parity code to insert between jmpret and shl
    and txdata, #$ff wc  'generate odd parity
    mov t1,#0
    rol t1,#9            'move c to 9th bit
    or  txdata,t1
    First instruction sets c if there is an odd number of 1's in txdata, next 2 shift carry·to 9th bit·temp variable, last instruction or's it with txdata
    edited 2008-09-17 21:51
    Mike, the problem is that it needs to tx 9bits, 8bits of data and 1 bit parity. FDS isn't setup to do this.
    edited 2008-09-17 22:03
    You might start with the Simple_Serial object. It's much easier to modify to handle 9 bit data since it's simple and all in Spin. You can easily change what I wrote to handle 8 data bits.
    edited 2008-09-17 22:22
    This will give some things to think about. Thanks guys.
  • Ken PetersonKen Peterson Posts: 806
    edited 2008-09-17 22:27
    Here's a modified FDS with parity.· Hope it helps.· I can't remember whether this was fully tested or not (or even where I got it).
    Ken
    ·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
    - Bjarne Stroustrup
    edited 2008-09-17 22:36
    Looks like it should work, also has a better way to do parity, simplies my code to
    muxc txdata,$100 'set the 9th bit to parity
    The receive path also checks the parity rather than just ignoring it.
    edited 2008-09-17 23:28
    Thanks KP, will test that tonight.
    edited 2008-09-18 01:32
    Can someone say why I get an error sending hex
    02 D2 00 00
    This is the string the devices debug test app uses to send to an inquiry to see if the device is working, and the device responds with another string
    So I assumed I could do this:
    serial.ser(string($02, $D2, $00,$00))
    Yet I get the error on Run that says "string characters must range from 1-255" regarding the $00
    What am I missing here?
    edited 2008-09-18 01:38
    a $00 has a special meaning the end of string, string adds one on the end and doesn't allow it in the string
    edited 2008-09-18 01:43
    Null ($00) termination is very common when handling strings. It is used in both SPIN and C. This means a string cannot have a $00 character in it except as a delimiter to indicate the end of the string.
    - Bjarne Stroustrup
    edited 2008-09-18 04:01
    The device responds with lots of $00 mixed in the string response, typically 4 - 6 bytes long, in some cases 3 rows or responses.
    The basic commands contain $00 mixed in between other hex values.
    Is it just the fact that FDS will not allow $00's, or the Prop in general?
    So far I am not getting a response without the complete string being sent 0x02 0xD2 0x00 0x00
    When I do this with the PC terminal they supply, the unit responds. But when I sent the truncated version 0x02 0xD2 there is no response.
    edited 2008-09-18 04:08
    OK I pulled some source code from the C app they provide as open source.
    Here is an example code:
    //CommandStructure: Startbyte 0x02, index 0 , command 0x80, no payload
    ·m_CommandArray [noparse][[/noparse]0] = 0x02;
    ·m_CommandArray [noparse][[/noparse]1] = 0x00;
    ·m_CommandArray [noparse][[/noparse]2] = 0x00;
    ·m_CommandArray [noparse][[/noparse]3] = API_CAPTURE_IMAGE; //0x80;
    ·m_CommandArray [noparse][[/noparse]4] = 0x00;
    ·m_CommandArray [noparse][[/noparse]5] = 0x00;
    ·if (checkFingerPresent) m_CommandArray [noparse][[/noparse]3] = API_CAPTURE_IMAGE_FINGERPRESENT;
    ·if (!WriteFile(m_hComm, m_CommandArray, 6, &nWritten, NULL))
    ··return FALSE;
    ·//CommandBuffer: Startbyte 0x02, no index, command 0x90, no payload
    ·m_CommandArray [noparse][[/noparse]1] = 0x01; //Will skip the CRC generation if set to 1.
    ·m_CommandArray [noparse][[/noparse]3] = API_UPLOAD_IMAGE; //0x90;
    ·//CommandStructure: Startbyte 0x02, no index, command 0x81, no payload
    ·m_CommandArray [noparse][[/noparse]3] = API_CAPTURE_AND_ENROL_RAM; //0x81;
    // Response byte values·····HEX value
    #define API_FAILURE······· 0x00
    #define API_SUCCESS······0x01
    Is there a substitute that may work to fill in the blank sections of the array on tx?· I will deal with the Rx as a secondary issue, since I just want to get the thing to respond via it's own debug for starters.·
    Thanks for any suggestions
    Post Edited (Originator) : 9/18/2008 4:14:48 AM GMT
    edited 2008-09-18 04:24
    Its just the str routine, if you want to send $00 use tx routine e.g.
    PRI send(arrStr, len) | i
    repeat i from 0 to len-1
    serial.tx(byte[noparse][[/noparse]arrStr+i])
    send(@m_CommandArray,6) will send 6 bytes of any value
    edited 2008-09-18 04:26
    cool i am testing it
    edited 2008-09-18 07:00
    CON
      _clkmode  = xtal1 + pll16x
      _xinfreq  = 5_000_000
        TAB  =  $09
        CR    = $0D
        i2cSCL1        = 28
        i2cSDA1        = 29
        i2cSCL2        = 0
        i2cSDA2        = 1
        INT1PIN        = 18
        INT2PIN        = 2
        LCD_Pin        = 7
        LCD_Baud       = 19200
        LCD_Lines      = 2
        PCF8575_Addr   = %0100_0000
        SCANTXA        = 3
        SCANRXA        = 4
        SCANTXB        = 5
        SCANRXB        = 6
        HOMEPIN        = 8
        REFPIN         = 9
        FAULTPIN       = 10
        DIRPIN         = 11
        BRAKEPIN       = 12
        OPA            = 13
        OPB            = 14
        MP3TX          = 15
        MP3RX          = 16
        SETUPPIN       = 17
        BUZZERPIN      = 19
        CURRENTPIN     = 20
        ENCAPIN        = 21
        ENCBPIN        = 22
        TEMPPIN        = 23
        FOTXPIN        = 24
        FORXPIN        = 25
        VIBEPIN        = 26
        PWMPPIN        = 27
        SERTXPIN    = 30
        SERRXPIN    = 31
    VAR
       Byte TestHardWareArray[noparse][[/noparse]6]
       Byte ResponseArray[noparse][[/noparse]6]                   ' buffer for numeric fields
       long  i2cAddress, i2cSlaveCounter
       'byte semID
       'long temp1, temp2
       Byte recbyte
       LONG Pos
    OBJ
         serial      : "FullDuplexSerial_Parity"
        'serial      : "Extended_FDSerial"
        'LCD         : "debug_lcd"
        'i2c         : "minimali2cdriver"
        'pwm         : "pwm"
        encoder     : "Rotary Encoder"
        'ser         : "FullDuplexSerial"
        spk         : "Piezospeaker.spin"    'beep(pin, freq, dur)
        'UARTS       : "pcFullDuplexSerial4FC" '1 COG for 4 serial ports
    PUB Init
      serial.start(26, 27, 0, 9600)    'ser.start(rxpin, txpin, mode, baudrate) : okay
      TestHardWareArray[noparse][[/noparse]0] := $02
      TestHardWareArray[noparse][[/noparse]1] := $00
      TestHardWareArray[noparse][[/noparse]2] := $00
      TestHardWareArray[noparse][[/noparse]3] := $D2
      TestHardWareArray[noparse][[/noparse]4] := $00
      TestHardWareArray[noparse][[/noparse]5] := $00
      repeat
        send(@TestHardWareArray,6) 'will send 6 bytes of any value
        receiveStr(@ResponseArray,5)
        if ResponseArray[noparse][[/noparse]0] == $02
         spk.beep (15,2200,400)'
        if ResponseArray[noparse][[/noparse]1] == $10
         spk.beep (15,2700,400)
        waitcnt(80_000_000 + cnt)
    PRI getrx
       recbyte := serial.rx
    PRI receiveStr(address,count) | c
      repeat count                   'start counting
       c := serial.rx                   'returns $00..$FF       c = first rec'd byte
       if c == CR        'c == CR  $0D
          byte[noparse][[/noparse]address] := 0
          return c                   'now return delimiter for optional checking
       byte[noparse][[/noparse]address++] := c          'update c
      return 0                       'default delimiter is zero
    Ok this is really messy test code but after many hours I have some steady response from the device back to the prop.· The responses aren't what I am expecting, but thats ok, at least they are talking.
    The device wants hex in and out, I have no idea what I am really sending and receiving in the above code.·Since are just a few routines I need to send to it, I was thinking of setting up Arrays as shown that get loaded with the hex for each requirement, with corresponding names for the arrays.·
    edited 2008-09-18 21:50
    Can someone please glance at this an see if something is missing?· I don't have a way to run the Prop tool and the device on the PC at the same time for monitoring what is really being received, but I am not getting the right responses, although there is response.· I hope to at least get an LCD going this afternoon to read the responses.
    I feel that the parity must still be an issue, the device uses ODD.· I am testing with the FDP parity version that was posted earlier in the thread.
    CON
        TAB  =  $09
        CR    = $0D
    VAR
       Byte TestHardWareArray[noparse][[/noparse]6]    '6
       Byte ResponseArray[noparse][[/noparse]4]
    OBJ
    PUB Init
       serial.start(26, 27, 5, 9600)    'ser.start(rxpin, txpin, mode, baudrate) : okay
       repeat
         receiveStr(@ResponseArray,4)
         'spk.beep(15,2000,400)
         if ResponseArray[noparse][[/noparse]0] == $02    'expected return value 1
          spk.beep(15,2500,400)
         if ResponseArray[noparse][[/noparse]1] == $08    'expected return value 2
          spk.beep (15,2600,400)
         if ResponseArray[noparse][[/noparse]2] == $00    'expected return value 3
          spk.beep (15,2700,400)'
         if ResponseArray[noparse][[/noparse]3] == $00    'expected return value 4
          spk.beep (15,2800,400)
         ResponseArray[noparse][[/noparse]0] := $FF     'change array to some different info
         ResponseArray[noparse][[/noparse]1] := $FF
         ResponseArray[noparse][[/noparse]2] := $FF
         ResponseArray[noparse][[/noparse]3] := $FF
          'serial.str(byte[noparse][[/noparse]arrStr+i])
          serial.hex(byte[noparse][[/noparse]arrstr+i],2)
          serial.tx(" ")
       c := serial.rx                   'c = first rec'd byte
       if  c == CR        'c == CR or TAB,
      return 0
    edited 2008-09-19 06:02
    Hey guys, I am quite stuck on this odd parity problem, having spent over 12 hours trying the various tricks mentioned, and had no success with the FDS_parity object.
    I think it's time to roll up my sleeves and figure this out myself so I can know the fundamentals, but assembly is out of the question at the moment, so bit banging is the only thing I'll have time to deal with.
    Can someone point me towards some learning resource to learn this serial comm stuff in a fast and practical way that applies to spin, so I can get an understanding and get this handled.
    edited 2008-09-19 07:42
    Tim, if you could glance at this, these are the changes I made based on your notes regarding the 4 port.· It seems I am getting a response, although if accurate is telling me there is an error. I don't think Iam sending the right format yet, but this is getting closer, the fact that it is responding with it's first start byte $02 followed by $00 (failure) may mean the rx is working.· It sends the same response no matter what it receives.·
    CON
        TAB  =  $09
        CR    = $0D
        LCD_Pin       = 14
        LCD_Baud      = 9600
        LCD_Lines     = 2
    VAR
       Byte TestHardWareArray[noparse][[/noparse]7]    '6
       Byte ResponseArray[noparse][[/noparse]5]
    OBJ
        ser         : "FullDuplexSerial4PortParity"
        LCD         : "debug_lcd"
    PUB Init
       ser.init
       Ser.AddPort(0,26,27,-1,-1,0,0,9600)
       Ser.Start
       if lcd.start(LCD_PIN, LCD_BAUD, LCD_LINES)            ' start lcd
        lcd.cursor(0)                                       ' cursor off
        lcd.backLight(true)                                 ' backlight on (if available)
        lcd.cls                                            ' clear the lcd
        lcd.str(string("Initializing..."))
        waitcnt(40_000_000 + cnt)
        lcd.cls
       repeat
         Send(@TestHardWareArray, 6)
         DisplayResponse
    PUB DisplayResponse
         lcd.cls
         lcd.hex(ResponseArray[noparse][[/noparse]0], 2)
         lcd.str(string(" "))
         lcd.hex(ResponseArray[noparse][[/noparse]1], 2)
         lcd.hex(ResponseArray[noparse][[/noparse]2], 2)
         lcd.hex(ResponseArray[noparse][[/noparse]3], 2)
          'ser.str(byte[noparse][[/noparse]arrStr+i])
          ser.hex(0,byte[noparse][[/noparse]arrstr+i],2)
          ser.tx(0," ")
       c := ser.rx(0)                'c = first rec'd byte
      return 0
    edited 2008-09-19 07:51
    ok, I just changed the send to the following and got Hardware Test OK Byte $08 back.
    PRI send
          ser.tx(0,$02)   'start byte
          ser.tx(0,$00)   'unused
          ser.tx(0,$D2)   'HW test
    The·first I have seen the Hardware Test OK·response so far!
    02 08 00 00
    02 is the response start byte, 08 is HWare·OK
    There is a pattern:
    success
    fail
    success
    fail
    fail
    success
    repeat
    Very close though.· Thanks Tim for that mod.
    Post Edited (Originator) : 9/19/2008 8:02:05 AM GMT
    edited 2008-09-19 17:16
    Looks ok, I tidied it up a bit and added a comment at the top.
    2 things to look at about the failures.
    1. Are you always sending the same message. If no calculate the parity by hand. Does the parity change, if so it could mean theres a problem with the parity generation
    2. Is there a terminating char when you send, e.g. are you meant ot send a CR or LF or both after sending the command sequence?
    edited 2008-09-19 18:42
    No, there will be maybe 10-15 standard messages. I am send the test as just one string that never changes.
    2. Is there a terminating char when you send, e.g. are you meant to send a CR or LF or both after sending the command sequence?
    No there are no terminations sent, just 4 bytes starting with 02
    Thanks for taking a look at it.
    Post Edited (Originator) : 9/19/2008 7:38:03 PM GMT
    edited 2008-09-19 19:43
    Wasn't clear, I meant in the test was it the same message - you say yes and it sometimes works, which suggests its not the parity calculation.
    What exactly is printed out when it fails, if the device sends CR,LF then its going to affect the next response. i.e. teh next response will have the 02 offset and a different hex printed out for the first hex number
    edited 2008-09-19 19:53
    Tim
    I found the error!
    This is what I was really doing to produce the inconsistent response after the parity issue was finally resolved with adapted 4port:
    PRI send
    Repeat
    The 'repeat' is the problem, remove it and 100% accuracy.
    I had modified the PUB Send from earlier that used the repeat and forgot to take out the repeat line.
    For some strange reason, only when I use the 6 separate lines of TX does it respond, no variation of ser.tx, ser.hex, ser.str works, only the 6 separate lines.
    In any case, this is working.
    edited 2008-09-19 19:57
    Great
    The following should work as well, if you fill the array how you did before.
          ser.tx(byte[noparse][[/noparse]arrStr+i])
  • Shane De CataniaShane De Catania Posts: 67
    edited 2008-11-09 05:18
    Hi Timmoore & others,
    Thanks for the 4 port serial object - it works great.. Just wondering if you can help me with a small problem though. I'm playing with a Lassen iQ GPS receiver which uses 9600,8,ODD,1. I am using your modified version of the serial object which has port 0 as default ODD parity. This works great for receiving data from the GPS but I cant seem to get it to work TXing to the GPS. I think the problem may be that when TX completes a byte, the TX line stays LOW - as compared to the GPS output which leaves the TX line HIGH. See attached picture - the upper trace is the propeller output to the GPS and the lower one is the output from the GPS. I have spent a fair amount of time looking at your code to see where it can be modified without much success unfortunately. The other possibility is that I am missing something entirely obvious of course! Help with this problem would be much appreciated.
    Thanks in advance,
    S
    News Flash!... Energizer Bunny arrested and charged with battery.
    246 x 137 - 30K
    odd.jpg 30.1K
    Can you post some code?
    I am guessing it is something else being overlooked.
    Post Edited (Originator) : 11/9/2008 8:43:55 AM GMT
