Simple Serial Communication Between 2 Propeller Chips
Holla,
I'm trying to simply have an array of slave chips listen to a master for commands, what i'm having trouble with is with the handshake, ie having the slave wait for the master to say hi. I've been trying to do this with the FullDuplexSerialPlus obj. If anyone has any recommendations, i would love to hear them[noparse]:)[/noparse]
Below is my master chip and slave chip code.
Thanks!
-tim
Master Code
Slave Code
Thanks!
-tim
Master Code
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
rx = 26
tx = 27
OBJ
Comp: "FullDuplexSerialPlus"
Slave: "FullDuplexSerialPlus"
PUB TwoWayCom | value
Comp.start(31, 30, 0, 57600)
waitcnt(clkfreq*2 + cnt)
Comp.tx(16)
Comp.Str(String("Comp communication initalized, starting slave chip initalization", 13))
Slave.start(rx, tx, 0, 57600)
Slave.tx(16)
repeat
value := Slave.getDec
Comp.Dec(value)
Comp.Str(String(13))
Slave Code
CON
rx = 26
tx = 27
OBJ
Master: "FullDuplexSerialPlus"
Master.start(rx, tx, 0, 57600)
repeat
repeat value from 0 to 100
Master.Dec(value)
pause(3_000_000)
PUB pause(delay)
waitcnt(delay + cnt)
Do remember that FullDuplexSerial is buffered and it may take a while after the last character is put into the buffer before it's actually sent. You really want some kind of acknowledgement to the slave from the master that it received a data item or group of data items from the slave.
