Ummm... That shouldnt have happened... ( Oscope + AC + ZAP!) — Parallax Forums
GICU812GICU812 Posts: 289
edited 2008-09-14 18:27 in General Discussion
Heres what I have, I was trying to play with the PIR sensor in a motion light, I have the light plugged in, with the HOT wire disconnected at the plug, there is no chance it was on.
My Parallax USB oscope ground was hooked on a cap, that I thought was in the DC section of the board I think it is anyway,·Im not going to mess with it anymore, but I wouldnt have hooked on it except I swore it was in the DC section.
My laptop·was having unrelated hickups, so I reached over to unplug the Oscope USB plug, as I unplugged it, my little finger dragged allong the bottom, I dont know if I was touching the USB connector, PC side of the USB connector, or maybe both, but I took a nice little jolt of 120AC
Well·my USB ports still work, scope still works, and my finger is fine though a little tingly.
This isnt the first time Ive had current seeping through my Oscope, Ive worked on projects in the past that were 5v with ground switched, powered·from my laptop USB for testing, and when hooked to the scope, and I turn off the projects switch, the stamp keeps running through the scope. I guess the scope grounds are frame grounded which grounds through the USB ground.
  • whickerwhicker Posts: 749
    edited 2008-09-13 05:22
    You're kind of giving hints about the problem from your description. So your 120V hot wire was disconnected, but what was the neutral wire doing? Neutral is not necessarily going to be at ground potential, specifically, the 0V potential of the USB ground. The capacitor isn't going to prevent a shock, because it lets AC right through, if that's what you're implying.
    And you say that you were switching ground instead of switching the 5V, which is also a very bad idea. Yes, since the configuration you list is powered all from the same supply, there's no reason why the black lead shouldn't provide a path back exactly the same as the power switch that was connecting to essentially the same USB (-).
  • GICU812GICU812 Posts: 289
    edited 2008-09-13 15:57
    Yea I was just relating a story, warning, FYI, whatever.
    I just thought some people might get a kick out of it, or at least something to think about next time they are working with thier scope.
    Im still not sure how I got AC in that section of the circuit, I have since abandoned that project, having found a better solution. But the power going right into the circuit is at least rectified, the input power goes right to a diode set that powers the rest of the board, and a relay that actually turns the device on. Theoretically the only part that should have had AC was the relay contacts and the far end of the diodes. Im sure if I really wanted I could trace it out and see why this happened.
    Post Edited (GICU812) : 9/13/2008 4:17:11 PM GMT
    edited 2008-09-13 18:00
    GICU812,
    Sounds like a polarity issue with your electrical outlet. Do you have an outlet tester such as one of these? ...
    www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100062242
    Beau Schwabe
    IC Layout Engineer
    edited 2008-09-13 22:58
    Sounds like good advice, I will check.
  • WhitWhit Posts: 4,191
    edited 2008-09-14 03:06
    Beau Schwabe (Parallax) said...
    Beau,
    I would not be without one of these. I use it all the time.
    Whit+
    edited 2008-09-14 03:24
    Oh, another interseting thing I've always noticed, when I touch one of the probes for my scope, without it connected to anything, it gives a rather clear 60hz wave. Im not touching anything else, on the couch, not grounded, always thought that was interesting.
    edited 2008-09-14 03:38
    Whit,
    "I would not be without one of these. I use it all the time." ... lol - I just used mine this evening.
    GICU812,
    "Oh, another interesting thing I've always noticed.... "
    That's normal where 60Hz is prevalent.... that's the grid, it's everywhere, it transmits like an antenna and your scope picks it up. In other countries you would see 50Hz as the normal.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 9/14/2008 4:07:30 AM GMT
    edited 2008-09-14 05:19
    I actually cant see Whits post, but I would have to agree, I find myself using this thing constantly, not sure how I lived without it, I guess a lot of things just didnt get fixed.
  • UnsoundcodeUnsoundcode Posts: 1,532
    Hi, another possibility from which some suffer more than others is ESD or static. Couch carpet clothing and atmosphere all make a difference. Static is something I suffer from badly especially in the cold foods section of Kroger, and it is usually way beyond 120v ·freaked.gif
    Jeff T.
