Light timer
I have the Basic Discovery kit but have not gotten anywhere near through the book. What I need to do is be able to have two small clusters of DC powered LED's (call one blue and one white) that can be triggered with a momentary switch to stay on for 30 minutes to one hour and then stay off. I would like two switches - one for blue and one for white and be able to control the times differently. I have seen circuits using 555 chips but this seems a better way. I am certain I will need a relay to control the power to the lights (suggestions?). Is there a simple program like this already? I searched to no avail. Thanks in advance.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
From what I have read this is too much. Before I get too involved I want to make sure I have all the parts a reasonable person would need. Do I need to trigger a relay?
SJL
thanks
For 200 mA, definitely use a relay. Radio Shack's reed relay at http://www.radioshack.com/product/index.jsp?productId=2062478 will work well here, just be sure to put a flyback diode across the coil (almost any silicon rectifier diode like a 1N4001) to protect your stamp, like the sketch shows.
