New Infared Module Range
New infared temperature sensing module announced this morning!
http://forums.parallax.com/showthread.php?p=750810
The documentation mentions "is designed for non-contact temperature measurements of objects placed within the sensor’s cone of detection" but I don't see a diagram or listing of what the detection range is.· I know it's early in the product release, but can any of the Parallax folks give us a rough idea of what it is?
Tim
Tim
Dave
Dave Andreae
Parallax Tech Support·
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
Dave Ratcliff· N6YEE
Dave
Dave Andreae
Tim
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/ProductID/520/List/1/Default.aspx?SortField=ProductName,ProductName
This will be posted in a few hours.
Dave
Dave Andreae
Post Edited (Dave Andreae (Parallax)) : 9/12/2008 10:36:46 PM GMT
"Users of this sensor should also review the MLX90614 datasheet from www.melexis.com. The datasheet includes technical information pertaining to the sensor’s cone of detection, precision and applications. When reviewing the datasheet please note that Parallax is using Melexis P/N MLX90614ESF-AAA, the single zone infrared thermometer sensor."
http://www.melexis.com/Sensor_ICs_Infrared_and_Optical/Infrared/MLX90614_615.aspx
There are datasheets and application notes at the bottom of the above page.
Duffer
So I can use this to watch my Lithium batteries charge properly? Or maybe this is a good item to use with a solar panel design. I strongly suspect that two of these can be used in a R/C autopilot to find a horizon by the temperature differences of ground and sky.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
····"The measured value is the average temperature of all objects in the Field Of View of the sensor."
What this means is that you can't just point it at a subject that subtends less than a 90-degree solid angle and expect to get an accurate reading of its temperature. So, for example, if you want to measure a lemming's body temperature, you'd better get up really close; if an elephant's, a little further back will suffice.
This also implies that you can't just collimate the field of view with a tube or use an aperture to restrict it, because the device will average in the temperature of the tube or of the mask surrounding the aperture. A longwave infrared-transmissive lens would probably work to focus the field of view, though, as would a parabolic mirror. Also, you might be able factor in the (known) temperature and coverage area of any collimator or aperture as a correction factor.
Notwithstanding these simple caveats, and without focussing, it appears that the device can yield highly-accurate temperature measurements from any subject that fills its field of view. This makes for a pretty exciting addition to Parallax's sensor range.
It can also be used to measure heat from a furnace at a distance. This might be useful for foundry work, glass blowing, and forged steel.
Personally I am more interested in autonomous flight.
