CMUCam3
I will soon begin with a CMUCam3, mostly for fun.
Is there any project using Propeller and CMUCam3?
Is there any good information out there besides CMUCam.org?
/Henke
Post Edited (port513) : 9/9/2008 8:07:38 AM GMT
/Henke
It really helps if it's with the same kind of camera [noparse];)[/noparse]
/Henke
Any other good source of info about CMUCam3?
What firmware is used in that obex example?
/Henke
One note, make sure you have the latest datasheets, the earlier data sheets had the TTL level serial port pinout wrong. If you have a meter check the power pin on the serial port its changes place in the data sheets! Thats the easiest way I found to tell if you have the correct datasheet. Also the serial port is 3.3V (not 5V has the datasheet says), its 5V tolerant but its output voltage is 3.3V so the 1K serial resistors are not required but it still works with them (also saves you if you wired usign the old datasheet).
Cmucam3 is really best suited for being a project's main cpu I think. Cmucam2 is interesting. Note that when you buy it, the cmucam3 emulates a cmucam2, minus a servo mount.
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
/Henke
Did your project progress and is this connection working ?
I found objects for MUCAM on the Obex , but it seems it is rather for CMUCAM1 or 2 ?
The TTL connection on CMUCAM 3 use 115 200 baudrate ; Is such speed possible with Fullduplexserial plus or extended Fulluduplex?
Cats92
Could you share the code with me ? I am a rookie, my email: zikasyp@gmail.com , thank you!
