Reading data from a 2764a eprom
Hi,
I have a old 6801 that I want to replace with the propeller, I want to read the machine code out of the eprom so that I can see exactly how it was programmed. I've included the data sheet ,from what I can tell you set the CE to 1 ,the OE to 1 and then do a inca from address 0 to address 8,000 , reading the 8 bit pattern from every one. Does this sound right ?
Thank's Brian
"Imagination is more important than knowledge..." Albert Einstein
www.PropelX.com
Thank's Brian
www.PropelX.com
'Still some PropSTICK Kit bare PCBs left!
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Thank's Brian
www.PropelX.com
