Are you talking about emulating a BS2 on a prop or getting an ordinary BS2 to work? If it is the latter, then I think that you are in the wrong part of the forum.
-Seth
The pessimist is never disappointed.
BS2_Func_Test.spin is included as part of the BS2_Functions object download from the Object Exchange. It illustrates how to use the BS2_Functions object from a Spin program. Take a look at it. When you compile BS2_Func_Test using the Propeller Tool, the Spin
compiler also compiles BS2_Functions to produce the resulting binary file which is normally downloaded to the Propeller.
-Seth
And, thank you Mike for your comment.
They must've taken the TEST.spin off of the objects. I only see the BS2Functions.spin. Let me know if you have a link.
