3.3 vDC to 5v DC
I am trying to interface the Prop with a device that requires a 5V signal and was looking for suggestion.· The 3.3V signal is not enough to trigger the other device.· I searched through the posts but could not find anything.· I am pretty sure I can use a transistor but I am not sure which one or·the·supporting circuitry needed to boost the signal.· Suggestion would be great.
Thanks··
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
Thanks··
WWW.HAPB.NET
WWW.HAPB.NET
Paul Baker
WWW.HAPB.NET
http://www.sparkfun.com/commerce/product_info.php?products_id=8745
Thanks for posting the balloon flight stuff. Very interesting and helpful.
JMH - Electronics: Engineer - Programming: Professional
I'd like to see the behavior that Paul claims for the Prop I in the Prop II, though. As I've noted elsewhere, the inputs on 74LVC logic chips are fully 5V-tolerant when powered from 3.3V and any open-drain ouputs can be pulled all the way to +5V. I'm not sure how this works for pins that can also be driven in totem-pole fashion (as in a microcontroller), though, i.e. whether the PMOS output transistors have to have body diodes or not and, if they do, whether they can be disconnected from the pin completely when the pin floats.
* You can tell which parts this will work with by looking at their data sheets. If the minimum guaranteed "on" voltage is 0.7 * Vdd (3.5V), it will work. Some parts spec 0.8 * Vdd (4.0V), though, which might work, even though it's beyond the 3.93V being input.
'Still some PropSTICK Kit bare PCBs left!
Paul Baker
The "LOW" voltage rides at the 0.6V band-gap, but the "HIGH" side pulls to the rail, depending on what side you are on. (3.3V or 5V)
Beau Schwabe
IC Layout Engineer
http://forums.parallax.com/showthread.php?p=711750
PJ's version is the complementary CMOS equivalent.... The main difference is that a LOW will go closer to the negative rail.
Both circuits (Bi-Polar or MOSFET) are true level shifters in the sense that you can drive (source) the pins HIGH on either side as opposed to just sinking them LOW.
Beau Schwabe
IC Layout Engineer
Seeing this recent activity I figured·I'd pulse in, too (yatta-hay).
WWW.HAPB.NET
