Propeller powered lathe tool changer — Parallax Forums
Brian_BBrian_B Posts: 844
edited 2008-09-05 18:49 in Robotics
Hi,
I just finished up on my lathe tool changer, It uses and encoder to sense current tool position and displays it on a LCD . You input the new tool position with a 4X4 keypad and hit enter ,it then uses a Gecko stepper driver to advance the tool to it's next position. There is a couple of bells and whistels I am going to add later ,but seems to work good for now.
Thank's Brian
·"Imagination is more important than knowledge..." ·· Albert Einstein
www.PropelX.com
  • DgswanerDgswaner Posts: 795
    that's pretty sweet! I've love to get a set up like that for my lathe. I haven't looked at your code, it adjust to give you the right cutting height for each tool or do you just secure it in the fixture at the correct height? I hate changing tools!!!
    Nice work. did you make a fancy box for your electronics?
    DGSwaner
    "When in doubt, use C4" - Jamie Hyneman, Myth Buster
