Help splitting a number into 2 parts
Oldbitcollector (Jeff)
I need to split a number into 2 numbers.
Example: 52 becomes x:=5 and y:=2
I'm using decx from Simplenumbers to grab the whole number
with this: s:= SN.decx(second,2)
Can someone help me with a routine to split both sides into two
different numbers into x & y?
OBC
(Here's the decx routine)
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
OBC
PUB decx(value, digits) | div
'' Returns pointer to zero-padded, signed-decimal string
'' -- if value is negative, field width is digits+1
clrstr(@nstr, MAX_LEN)
digits := 1 #> digits <# 10
if (value < 0) ' negative value?
-value ' yes, make positive
nstr[noparse][[/noparse]idx++] := "-" ' and print sign indicator
div := 1_000_000_000 ' initialize divisor
if digits < 10 ' less than 10 digits?
repeat (10 - digits) ' yes, adjust divisor
div /= 10
value //= (div * 10) ' truncate unused digits
repeat digits
nstr[noparse][[/noparse]idx++] := (value / div + "0") ' convert digit to ASCII
value //= div ' update value
div /= 10 ' update divisor
return @nstr
x := v / 10
y := v // 10
v := string('52')
x := v[noparse][[/noparse] 0 ] - "0"
y := v[noparse][[/noparse] 1 ] - "0"
n := 52
x := n / 10
y := n // 10
or are you after something ore complicated ?
Am I wrong or:
x := N/10
y := N - (x*10)
Regards.
Alberto.
I suspect because it is returning a string. An easy way to convert it?
OBC
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
OBC
OBC
