For Chip Gracey : Thumb PASM on the Prop II
hippy
Would it be possible to add some support for Thumb-Style PASM for the Propeller Mk II ?
Not extensive support, just an extra barrel shifting extra instruction which would make it much easier and quicker for LMM routines to convert 16-bit Thumb-LMM to 32-bit PASM which would mostly be usable.
Because it's LMM handled there's no need for handling jumps or calls; they can be trapped by the LMM interpreter using opcode "000000" and handled within the LMM kernel.
There would be a lot of expanded-to-PASM opcodes which wouldn't make a lot of sense but it would allow a whole host of those which do and woul make life a lot easier for LMM writers.
While the proposal here uses Cog locations $000-$00F for registers, tie that to the task switching else where and you've got 8 tasks per Cog capable of running Thumb-LMM with very little overhead.
Post Edited (hippy) : 9/3/2008 10:15:59 PM GMT
oooooo 0 kkkkkkkkk opc $000,#$kkk | | | `-----------------. |_____ |________ oooooo 0011 1111 000000000 kkkkkkkkk
oooooo 1 r dddd ssss opc $00d,$00s {NR}
|_____ | |___ |___
oooooo 11r0 1111 00000dddd 00000ssss
[noparse][[/noparse]code]
