OEM BS2 - Rev A1 - Cause Reset if Remove Serial Cable which connect thru Prolif
All,
I have a OEM BS2- Rev A1, it is program thru a USB Serial Port from Prolific, whenever I remove the USB port with the OEM BS2 Rev A1 connector at the other end, it will cause a system reset of the Basic Stamp. Anyway to prevent that from happening?
best regards,
CGTan
best regards,
CGTan
Chris Savage
Parallax Engineering
CGTan
You can try placing a 1K or so resistor between the DTR pin and Vss. This will effectively attenuate the DTR signal. It depends though on how the USB Serial Port from Prolific deals with this signal. If it's a passive capacitor reaction due to unplugging the USB Serial then the 1K resistor will probably work fine... if the "brief toggle" is active or driven in any way it may not work.
Beau Schwabe
IC Layout Engineer
