How do you see how much of RAM you've used up?
Hello.· Is it possible to view how much RAM your program has used up?· (i.e. similar to viewing how much of the program EE you've used up but for RAM).
After you compile, in SX toolbar·select Run and then from that drop-down menu select·Device.
No information about that file type is available in the sxkey manual, nor on sxlist.com
Sxkey does not require the .map file.
Perhaps PJMonty (who maintains the IDE) can give us more info about·the .map files·format.
Then it might be possible to convert it to ascii text.
(or perhaps such a tool already exists).
regards peter
127 Bytes (??)
Registers $0D-$0F -- 3 bytes of true "global" user ram
Registers $10-$1F -- 16 bytes of "normal" variable space
Registers $30-$3F, $50-$5F, $70-$7F, $90-$9F, $B0-$BF, $D0-$DF = 6 x 16 bytes = 96 bytes array/bank RAM
Registers $F0-$F4 = 5 bytes (array)
Registers $FD-$FF = 3 bytes (array)
__INTPARAMFSR stack (5 bytes SX/B 1.x, 6 bytes SX/B 2.0) = can be claimed if you have NOPRESERVE on and know what you're doing
__PARAM1-__PARAM5/__PARAMCNT = 5 bytes of global ram can be used in all sorts of ways, but make sure use doesn't conflict with high level SX/B commands
On the SX48 in addition to the extra 16 byte banks, 2 more globals are used and $FD-$FF are shadow TRIS registers.
SX/B 2.0 uses one more variable in the INTPARAMFSR stack (for PARAM5/PARAMCNT save/restore), and aligns bytes in $Fx slightly differently.
