Greater than and less than Code — Parallax Forums
Brian_BBrian_B Posts: 844
edited 2008-09-01 23:59 in Propeller 1
I'm trying to make a descion if the value of a variable is between 1 and 8. I've tried a couple differnt ways but I can't get it to work ,here is one sample
code.......
IF variable1 =<1 & =>8
do somthing
ELSE
do somthing differnt
Thank's Brian
·"Imagination is more important than knowledge..." ·· Albert Einstein
www.PropelX.com
    edited 2008-09-01 20:07
    You need: IF variable =< 1 AND variable => 8
    'Still some PropSTICK Kit bare PCBs left!
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2008-09-01 20:08
    I think you have it backward. Here is a couple of options
    if variable>0 and variable<9
      doit
    else
      dontdoit
    case variable
      1..8:
        doit
      other:
       dontdoit
    I have just lately started using case and find it very handy for some things.
    edited 2008-09-01 21:39
    how about this bit of code:
    if (variable - 1) >> 3
      code for variable not between 1 and 8
    else
      code for variable between 1 and 8
    This is mathmatical form of the logical expression, a result of 0 (FALSE) indicates the variable is between 1 and 8. Don't know which form is faster.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 9/1/2008 9:44:52 PM GMT
  • Brian_BBrian_B Posts: 844
    Thanks' Guys,
    I used Phils version just to get it done ,but I plan on checking into the other ones
    Thank's Brian
    www.PropelX.com
