Multiple PWM outputs from one COG?
godzich
Hi,
I am completely new with the Propeller, so please bear with me.
I have the prototype kit and have not powered it yet, just learning about this interesting technology by doing some serious reading.
Before I go forward using the propeller chip -please enlighten me - is the following possible:
1. I need 24 PWM outputs with fixed frequency
2. The PWM frequency should be in the 600Hz...1200Hz range
3. The PWM resolution need to be at least 10 bits, preferrably 12-bits
4. The PWM outputs needs to be interleaved, so that the turn on is timely divided between the channels (no simultaneous turn on of the waveforms)
5. Can this functionality be placed in one COG, or how many are required?
I appreciate any comments, either based on experience or just wild guesses!
Thanks in advance for your help [noparse]:)[/noparse] I hope to become also a propellerhead some day [noparse];)[/noparse]
Christian
The future does not exist - we must invent it!
Post Edited (godzich) : 9/1/2008 10:49:19 AM GMT
Christian
8-channel PWM output, one cog, 23KHz for 8-bit resolution (updated 17 Jul 08)
http://forums.parallax.com/showthread.php?p=730527
Aka: CosmicBob
loop cmp timer,pw1on wz if_z or outa,pin1mask cmp timer,pw1off wz if_z andn outa,pin1mask cmp timer,pw2on wz if_z or outa,pin2mask cmp timer,pw2off wz if_z andn outa,pin2mask .... and so on for pwm 3..24 add timer,#1 and timer,MaxCycles djnz count,#loopwith that you can produce 24 interleaved PWMs. If you set MaxCycles to 1023 then you get 10bit resolution.
The compares for every PWM needs 16 clocks * 24 PWMs + perhaps 16 for the loop = 400 clocks.
Then the PWM frequency is 80MHz / 400 / 1024 = 195 Hz.
In other words: it is not possible with 1 cog. You need 3 .. 4 cogs for 600Hz and 10Bit resolution.
The code above is only for estimating the needed clock cycles and not a complete program. It also lacks the rdlongs for reading the PW parameters from HubMemory.
Andy
THX for your fast replies. This seems to be great forumn with nice and skilled people [noparse]:)[/noparse]
I might be able to relax my frequency and channel requirement. With this assebly loop it should the be possible to produce 18 channels at 10 bit resolution at a PWM frequency at about 250 Hz. That could be still ok. The idea using the vide generator producing 8 pwm outputs is also very interesting. However, I would need then 3 COGs for 18 channels. In my application I probably need all the other GOGs for other control purposes, so the assembly approach using only one is probably the way I go. But there is still lots to learn before I'm that far [noparse]:)[/noparse]
Just a little outside the topic:
Are the Parallax software tools compatible with Vista x64?
Yesterday evening I dowloaded the SW and the installation went fine. When I tried to lauch the application a blue screen flashed and my PC rebooted. What the heck? I was too tired to investigate, and continue today after my work... [noparse]:([/noparse]
Thanks for all your kind help.
Christian
Just swap the xtal from 5MHz to a 6MHz and get more "breathing room".
Kaj
If the propeller stops - the pilot starts sweating...
