Making Solid State Relays
william chan
Hey,
Anybody knows the best way to make a solid state relay from 2 mosfets?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
No, there are types made specifically for AC or DC. You definitely want to use the right one. Now, on the other hand, the AC units will typically run at voltages lower than what they state. DC units usually specify a range you want to stay in.
Chris Savage
Parallax Engineering
If you need only DC, why buy DC rated SSR? Why not just use a mosfet or any other transistor?
www.fd.com.my
www.mercedes.com.my
Chris Savage
Addendum: One additional note regarding AC SSRs: These usually include a zero-crossing detector, which prevents the load from being switched mid-cycle and causing a current surge. Normally, such a capability is provided by triac-type SSRs and not those that employ back-to-back MOSFETs.
Post Edited (Phil Pilgrim (PhiPi)) : 9/1/2008 4:40:03 AM GMT
www.fd.com.my
www.mercedes.com.my
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Beau Schwabe
IC Layout Engineer
