APRS Packet Radio
Is Packet radio doable with the propeller?· if it is then a really small unit could be built.
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Digital Technology Group
Post Edited (Sniper King) : 8/28/2008 9:34:46 PM GMT
Michael King
R&D
Again, my guess would be yes and I am curious what steps to take. Someday I would like to do a high altitude balloon so I briefly looked at what others were using.
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
http://users.rcn.com/carlott/avr/avr_mx614_schematic.PDF
Michael King
R&D
I tried to code a general APRS device on the Prop using a modem chip and some info from the Tucson, but the unusual encoding and CRC's killed my enthusiasm fairly quickly.
Check out the Tucson Radio site, it has a wealth of APRS info, including their AX.25 encoder board. It uses the same modem chip that I looked at, but the code versions that are floating around are a bit out of date. If you are familair with PIC programming (I am not), you can probably start with their code and port it to the Prop.
http://www.tapr.org/aprs.html
Cheers!
Michael King
R&D
Michael King
R&D
This thing would be easy to make and very cheap. Packet radio would be flooded with them and there would be a huge growth in packet radio.
Of course my need is selfish.· I want the ASB (Autonomous SailBoat) to be exclusively run by the Propeller.· Communication,guidance, everything!
Michael King
R&D
Post Edited (Sniper King) : 8/29/2008 9:32:03 PM GMT
The thing I don't like about the miniature trackers is that they either send APRS packets or one way messages, but can't seem to do both. What would be perfect is an object that you could just Start, and had a method such as SendAPRS(@lat, @long, @speed, etc.), or SendUNPROTO(@station, @message).
Tim, one thing I noticed about the AX.25 protocol is that the bits of the station field are all shifted for some reason.
KI6HBT
I am reading the APRS manual to see how to produce acceptable ax.25 frames.· It uses a lot of big words though :-).
Michael King
R&D
The radio I currently use on only 0.384 watts output but I can pick up the signal for miles, especially when airborn.· For a radio you might want to look at incorporating the MX146 (http://www.argentdata.com/products/radios.html).· It is a SMT 2-meter transmitter designed for short burst of data (5:1 ratio).· It is completely programmable and has the standard preset APRS frequencies used around the world.·
Eventually, I would like to incorporate 2-way·APRS messaging using the Prop but my·SPIN knowledge is still·on the low end right now.· I know I would use the object if it was available.
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
