Solar cell mounting
While at the Propeller Expo in Ohio last weekend. I Picked up some solar cells that Bean was selling for a great price.
Now I want to mount them in a weatherproof, permanent enclosure. My aim is to charge a battery and power some white LED's to give some dim accent lighting near the fence that encircles my backyard.
Looking for any ideas on...
Thanks in advance!
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
- what to attach the Solar cells with
- what to cover the cells with...such as Lexan, plexiglass or real glass
- leave an air gap between the cells and the clear cover just mentioned?
- are solar cells tolorant of cold? Should this be mounted in such a way that I can easily bring it in during the winter? I'm in upstate NY where the temps can go down around zero during the winter
Thanks in advance!
Brian
Ironically, the passiveness of the solar cell seems to work against itself. If you have a wind turbine producing the same electricity, all that spinning is in some ways self-cleaning.
Snow is a wonderful reflector of light and will often boost your output in the winter far above the output in the summer. Passive solar heated homes in snow country have been able to reach 95% of their winter heating requirements with solar energy alone.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
I got a bunch of them from the show as well.. As soon as I figure out how many
I need to create around 7-9 volts, (both voltage and amp) I'm planning on
buying two pieces of plexi from the hardware store and mounting them in between.
Should protect them from damage. Better ideas?
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Think of them like a battery and you can do the following:
1. Connect them in series (+ to -) (- to +) etc. to get a higher voltage level. To get·6 volts you would need 12 of them in series (e.g. 12 * 0.5 = 6).
(neg)<---(-)(+)--(-)(+)--(-)(+)--(-)(+)--(-)(+)--(-)(+)--(-)(+)--(-)(+)--(-)(+)--(-)(+)--(-)(+)--(-)(+)-
(pos)<
2. Connect the series connected·6 vdc solar cells now in parallel to increase the current (+ to +) and (- to -).
(pos)<
Here you still have the 6 vdc but at 4 times the current.
Post Edited (T&E Engineer) : 8/29/2008 1:51:20 PM GMT
I was somewhat misleading there.... I was more worried about the battery in the cold. It's a 12 V lead acid battery. And the lights it will be powering really are only needed during warmer weather. I won't be out in the backyard at night during the winter.
I should clarify my mounting question some.... The cells are glass encased with just 2 foil strips for the electrical connections on the rear. There is no mounting holes. I thought about hot glue, but the constant heating and cooling....I've never had good luck with hot glue.
The adhesive is what I was looking for ideas on.
Brian
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Do you of any thing better to use
I have use hot glue this not work very well in the sun
I am looking for some thing that is better than this any·
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/29/2008 11:02:10 PM GMT
Use Caulk designed for high heat outdoor use, but as mentioned, make sure it doesn't have acetic acid.... A quick test, if it smells like vinegar, it's the wrong stuff.
Beau Schwabe
IC Layout Engineer
'Still some PropSTICK Kit bare PCBs left!
Brian
Before I re-invent the wheel, have you already determined the number of cells required
for powering your SpinStudio board? [noparse]:)[/noparse]
OBC
Thank You For that link to the marine-grade product like BoatLIFE silicone rubber sealant
That will help a lot
One thing·I want to ask you dose this·turn yellow in the sun after a while
··Thanks for any·
Sam
I have to admit, I'm using these for a non-propeller application (gasp!)
They are 4 volts open circuit, less under load. 80 mA short circuit. I would figure 3 in series to produce the voltage you might need, then put more strings of 3 in parallel to increase the amperage. you may end up with a 3x3 array, or 3x10 array, however many cells you happen to have bought.
I'm hoping to charge a 12 V battery, so I may use 4 cells in series. I'll have to do some more tests before I mount them permanently.
Brian
