Drop-in Keyboard Driver
Hi All,
While at the expo I picked up one of those mini keyboards from Bean:
http://forums.parallax.com/forums/default.aspx?f=25&p=4&m=243918
I have already hooked it up and gotten good text from it on screen with TV_Text and a CASE statement to convert the serial codes to ASCII compatible (Thanks Mike Cook).
I'd ideally like to be using this KB with propDOS and with other software designed for the prop.
SO I'd like a drop-in replacement for the PS2 KB driver, this would in effect let me use it anywhere anytime with just a re-compile.
Before I start trying to cobble this together has anyone already done this.. or started to do this?
I have checked the OBEX and done some searches and have not found any evidence of this idea..which I find surprising.
Rick
Rick
I did some work on a nearly drop-in replacement using code that was posted
from several other members here.
http://forums.parallax.com/showthread.php?p=702473
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
I'm gonna go ahead and finish it up for the PropBerry
thanks for the heads up
Rick
