SUPERDUPER low power!
OK, so I have finally been able to get extremely low power draw out of the Propeller (.007ma). Now what Voltage regulator do we use to keep that extremely low power?
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Digital Technology Group
Michael King
R&D
Paul Baker
500 μA per MIPS (MIPS = Freq in MHz / 4 * Number of Active Cogs)
I have the Main program running·in COG 0 and the FullDuplexSerial object opens another COG so...
80000 / 4 * 2=20000uA
or 20mA
·I also have a PIR Sensor onboard that draws about 100uA and when activated draws 12 mA.
add 12ma to·the propeller draw·and we get a maximum draw of 32ma.· Add an OOPS factor and spiking and I imagine about 100ma would be a safe VR
Michael King
R&D
Paul Baker
Michael King
R&D
If maximum power is drawn infrequently, the quiescent current required by a switching regulator circuit may disqualify it in favor of a "micropower" linear regulator. OTOH, if you charge up a supercap during maximum power periods, you could simply turn off the switcher during quiescent periods. You'd need some sort of fail-safe mechanism to force the switcher "on" if the supercap drained too far, though. Yet another option would be to employ both regulator types, automatically switching between the two, depending on the current draw, thus obviating the supercap.
Michael,
How were you able to measure a 7uA current draw? Do you know how accurate that measurment is?
'Still some PropSTICK Kit bare PCBs left!
This is being used on the US/Mexico border to detect illegal immigrants so sometimes there are 20+ people in a line walking north.· The PIR sensor sends a 2 second pulse when activated.· That is what trips my WAITPEQ statement.· So we would see multiple activations from a single group.
{{ PIR UDA Sensor.spin, v1.1,Michael King ┌──────────────────────────────────────────┐ │ Copyright (c) 2008 Michael S. King │ │ See end of file for terms of use. │ └──────────────────────────────────────────┘ }} CON CON _clkmode = rcslow '_xinfreq = 5_000_000 OBJ Clock : "Clock" Send : "FullDuplexSerial" PUB main dira[noparse][[/noparse]16]:=1 clkset(%00000001 , 0) ' Set internal oscillator to RCFast and set PLL to start waitcnt(cnt+120_000) ' Set internal oscillator to RCFast and set PLL to start repeat waitpeq(%0100, %0100, 0) 'Wait port Port 3 to go high clkset( %01101000,80_000_000 ) waitcnt(800000+cnt) clkset( %01101111,80_000_000 ) waitcnt(800000+cnt) outa[noparse][[/noparse]16]:=1 send.start(31,30,0,9600) ' start FullDuplexSerial waitcnt(20_000_000+cnt) 'Wait a bit for the XTEND to be ready send.str(string("<*00000001*S*>")) 'Send activation of sensor Message waitcnt(20_000_000+cnt) ' Wait for message to be sent send.stop outa[noparse][[/noparse]16]:=0 clkset(%00000001 , 0) ' Set internal oscillator to RCFast and set PLL to start waitcnt(cnt+5_000)
It should be on for no more than 2 seconds.
Michael King
R&D
Paul Baker
Michael King
R&D
Paul Baker
