Can someone show me how to consolidate this code?
I need a little help trying to consolidate my code. I have built a full size humanoid with 25 servos hooked up to a servo controller and I need a cleaner code.
I'm not the greatest coder in the world and any help would greatly be appreciated.
Second purpose for this is to cut the amount of memory being used. I've got an IR detector for remote control, which works great, but I can't get all my routines on the chip so I can select the routine I want for example : "walk_forward", "turn_to_right", etc.
Also, what's a simple way to add more memory to the propeller?
In the dat section, place your string like,
dat
doit byte "your string here",0
then, simply call the string like
ssc.str(@doit)
You do need to code "smarter". First of all, you need to define what you want your robot to do, how you want the Propeller and the servo controller to work together. For example, having string constants is a very inefficient way to define movements, particularly if only a couple of servos change position at a time. You could have a table of movement changes where each entry is 3 bytes long. If the first byte is 128, the next two bytes is a 16-bit pause time in 10ms units. If the first byte is 129, the next two bytes is a "T" value. If the first byte is 0 to 127, it's a servo number and the next two bytes is a 16-bit servo position. You need a routine that takes a starting byte index into the table and processes all the entries up to the first pause and returns the byte index to the next set of entries. Your routine would go through these entries, transmitting a command or series of commands to the servo controller, then do the pause (WAITCNT) and return the index to the next place to start. If the pause time is zero, this marks the end of a sequence of movements.
Your first "attention" set would be written (in a DAT section) as:
If your table was like in the previous post, you'd call it like
This would start at Item1 and return the index after the "byte 128, 20_000 & FF, 20_000 >> 8" which you'd use to call it again instead of the "0". It would return -1 after the end of a sequence of movements.
Erik, your explaination is simple but not enough info for me, but it makes sense.
Mike, I know you live on this forum and I've read your replies. You definitely know your stuff, but you went over my head.
Can you rewrite my code the way you would do it so I can see what your talking about. I can then rewrite all the other ones (there's about ten routines).
Or just explain what each number is doing.
Can you explain this part a little better.
The "byte 1" is just a reference to the first row of commands, right? Then byte 2 to the next row, and so on.
The "1500 & $FF", I don't understand.
The "1500>>8", I don't understand either.
The routine I wrote just goes through the table picking up a byte value and a 16-bit word value (as two bytes) that immediately follows the byte. The byte value is either a servo number (0-127) which is followed by a servo position (the 16-bit value) or the value 129 which is followed byte a time (ramp?) value or the value 128 which is followed by a value used for the WAITCNT. Since this value is only 16 bits and the WAITCNT values are pretty big, I scale it by 10_000 clock cycles. If this WAITCNT value is zero (otherwise invalid), it marks the end of a sequence.
The interpreter is written to process one line of text ended by the WAITCNT value. It's also written so it can be called again immediately as shown to continue with the next line of text.
The best way to understand what I've written is to hand execute it. Get a big piece of paper and start with the "nextStart := interpret(@Item1,0)". Pretend you're the Propeller and write down that statement. Do what the statement says and write down any changed variables and anything that's transmitted to the servo controller, then do the next statement and write down any more changes. Keep going until it's done. It sounds like a lot of work, but you'll learn a lot.
Post Edited (Mike Green) : 8/28/2008 2:38:42 AM GMT
The comma separates successive bytes
"1500 & $FF" compiles to a byte computed by taking the value 1500 and stripping out the lower 8 bits (using "& $FF") (the value 220).
"1500 >> 8" compiles to a byte computed by taking the value 1500 and shifting it right 8 bits to extract the upper 8 bits (the value 5).
"1500 & $FF, 1500 >> 8" your taking the lsb and the msb out of the 1500 or whatever the position number will be.
Now things are making sense.
You have expanded my understanding, thanks for you patients!
