Changing Clock Frequencies on the fly... — Parallax Forums
Sniper KingSniper King Posts: 221
edited 2008-08-27 21:53 in Propeller 1
PIR UDA Sensor.spin, v1.1,Michael King
│ Copyright (c) 2008 Michael S. King       │
│ See end of file for terms of use.        │
CON
VAR
OBJ
        Clock : "Clock"
        Send : "FullDuplexSerial"
PUB main
Clock.init(5_000_000)
clock.setclock(RCSLOW)
dira[noparse][[/noparse]16]:=1
repeat
  waitpeq(%0100, %0100, 0)   'Wait port Port 3 to go high
  clock.setclock(XTAL1 + PLL16X) 'Set clock to really fast
  waitcnt(1000000+cnt)
  outa[noparse][[/noparse]16]:=1  'PIN High of PWR to switch XTEND module on
  send.start(31,30,0,9600)  ' start FullDuplexSerial
  clock.pauseMsec(500)   'Wait a bit for the XTEND to be ready
  send.str(string("<*00000001*S*>")) 'Send activation of sensor Message
  clock.pauseMsec(500)   ' Wait for message to be sent
  outa[noparse][[/noparse]16]:=0
I set the clock to RCSLOW in the beginning of the program then When the pin 3 goes high it allows the program to continue.· The first thing it does is to set the clock speed to XTAL + PLL16x.· Program execution stops here. Don't Work
<subject line added by Moderator>
Post Edited By Moderator (Paul Baker (Parallax)) : 8/27/2008 8:58:28 PM GMT
    edited 2008-08-27 20:12
    You can switch to RCSLOW or RCFAST anytime, but when you switch to an XTAL(+PLL) mode, you need to first turn on the crystal oscillator (and the PLL, if you're going to use it), give·the crystal·10ms to settle (the PLL takes only about 10us), THEN switch over to it. This assumes that the crystal (and PLL) were already off. Otherwise, if the crystal (and PLL) are enabled, you can just switch between any PLL division, OSC input, RCSLOW, or RCFAST mode. Of course, you'll want to turn off the XTAL(+PLL) if you want to save power while in RCFAST or RCSLOW mode. RCSLOW mode takes about 8uA (with BOE on), plus 1.5uA per cog, as the chips runs at ~20KHz. When you want to speed back up, turn on the XTAL (and PLL), wait 10ms, then switch over to them.
    Chip Gracey
  • ColeyColey Posts: 1,130
    edited 2008-08-27 20:13
    Michael,
    without seeing your clock object it is difficult to see what could be happening.
    Look at the attached object that shows how to change the clock spped on the fly, I wrote it for autonatically detecting between different gaming platforms.
    Coley
    PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
  • Sniper KingSniper King Posts: 221
    edited 2008-08-27 21:44
    What is BOE?
    ·- Ouch, thats not suppose to be hot!··
    Michael King
    Application Engineer
    R&D
    Digital Technology Group
    edited 2008-08-27 21:51
    Sniper King said...
    What is BOE?
    BOE is Brown-Out Enable. This is 'on' when the BOEn pin = VSS. It keeps the brown-out detector on at a cost of about 4.5uA. If you made BOEn = VDD ('off'), then you could save that much current, but the chip wouldn't reset itself due to a low-voltage condition.
    Chip Gracey
  • PhilldapillPhilldapill Posts: 1,283
    BOE is Brown Out Enabled. Should be grounded to enable it. I believee shuts down the chip if the voltage gets too low.
