Changing Clock Frequencies on the fly...
I set the clock to RCSLOW in the beginning of the program then When the pin 3 goes high it allows the program to continue.· The first thing it does is to set the clock speed to XTAL + PLL16x.· Program execution stops here. Don't Work
<subject line added by Moderator>
Post Edited By Moderator (Paul Baker (Parallax)) : 8/27/2008 8:58:28 PM GMT
PIR UDA Sensor.spin, v1.1,Michael King
│ Copyright (c) 2008 Michael S. King │
│ See end of file for terms of use. │
CON
VAR
OBJ
Clock : "Clock"
Send : "FullDuplexSerial"
PUB main
Clock.init(5_000_000)
clock.setclock(RCSLOW)
dira[noparse][[/noparse]16]:=1
repeat
waitpeq(%0100, %0100, 0) 'Wait port Port 3 to go high
clock.setclock(XTAL1 + PLL16X) 'Set clock to really fast
waitcnt(1000000+cnt)
outa[noparse][[/noparse]16]:=1 'PIN High of PWR to switch XTEND module on
send.start(31,30,0,9600) ' start FullDuplexSerial
clock.pauseMsec(500) 'Wait a bit for the XTEND to be ready
send.str(string("<*00000001*S*>")) 'Send activation of sensor Message
clock.pauseMsec(500) ' Wait for message to be sent
outa[noparse][[/noparse]16]:=0
Chip Gracey
without seeing your clock object it is difficult to see what could be happening.
Look at the attached object that shows how to change the clock spped on the fly, I wrote it for autonatically detecting between different gaming platforms.
Coley
PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Digital Technology Group
Chip Gracey
