PPDB: Awesome product!
Just getting thing back in semi-organized order in my electronics shop.
Just hooked up the PPDB (Propeller Professional Developement Board)
What a sweet product! Ground connections are already established for most everything,
so hooking up video was just a matter of attaching data lines. I even discovered I think
I like the video better omitting P12. (At least with the Graphics Demo)
(Want to fine tune the video? Run P12 through POT1 to V0) Neat stuff!
Paul, you did a fantastic job with this product! It's impressive all the way around.
Any chance you could publish some more specs on DS1, DS2, and DS3?
Nevermind, the Schematic had everything I was looking for!
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 8/26/2008 2:34:52 AM GMT
OBC
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/26/2008 2:40:31 AM GMT
Could you give me a simple example for lighting 1 segment 3.3/Grd?
Thanks!
OBC
Missed my initial ground connection! (Started getting spoiled from the rest of the board. [noparse]:)[/noparse]
Pretty!
Edit: Just hit me.. scrolling text is going to be a breeze on this product!
OBC
Paul Baker
are perfect! DP=dot G1-H=center F-A1=standard numbers. perfect.
Care to share the logic of the connection names?
Only only one gripe.. The connection names are pretty small to read.
I'll have them committed to memory soon, but until then a magnifier will be in my box.
(Ordered a PE-style case from the hardware store for the PPDB.)
OBC
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/26/2008 3:22:28 AM GMT
(given proper .spin) Nice..
A little off topic, but with the new Protoboards and PPDB going USB,
I get the sense that Parallax is moving away from the Propplug?
OBC
Paul Baker
You've just got to check this thing out!
The PPDB is the board I didn't know I wanted when I built my first propeller setup.
Time to boot up Word and start the next beginners guide.
@Paul: I'm betting you've already written some .spin code for this thing?
OBC
Paul Baker
My segments are turning on and off in an intelligent order. (I haven't overwrote the EEPROM yet)
OBC
Your whipping me into a frenzy!
Whit+
(Just using the onboard stuff..)
Playing with these display modules has taken me back to the 80's.
Edit: Bet a KIM-1 emulator would be cool on this thing
(Chip: We'll make your chip emulate a Commodore yet! <smirk>)
OBC
Post Edited (Oldbitcollector) : 8/26/2008 3:10:32 PM GMT
watch out. Already thinking up new game ideas and you just now really examined it.
JMH
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
JMH
As for the small text.· That will go into notes for a future run.· Now is the time to get feedback from our customers and try to make any adjustments or improvements if we can.· We appreciate the feedback and are glad you are enjoying your new PPDB!· Take care.
Chris Savage
Parallax Engineering
Post Edited (Chris Savage (Parallax)) : 8/26/2008 10:58:28 PM GMT
Truth can be dangerous... Trust can be deadly.
"I'm leaving!"
"But I haven't set you on fire yet!"
They should have had Chip sign the bottom of them and released them as "limited edition"
Maybe I'll bring mine with me to Propstock and have him sign it. [noparse]:)[/noparse]
OBC
They are a little pricey given what they are, but are perfect for working with this board.
OBC
This has wiring diagram and a counter to test digits on all six LED digits.
Edit: Much more refined version (no flashing numbers)
OBC
Post Edited (Oldbitcollector) : 8/27/2008 2:56:45 AM GMT
"I'm leaving!"
http://www.allelectronics.com/make-a-store/item/JW-140/140-PIECE-JUMPER-WIRE-ASSORTMENT/-/1.html
http://www.allelectronics.com/make-a-store/item/JW-350/350-PIECE-JUMPER-WIRE-ASSORTMENT/-/1.html
Paul Baker
A long time ago I picked up a set of pre-cut wires for the protoboards but have yet to use them. Want an inexpensive solution?? What works best for me is the solid telephone wire. Find a building that is having some work done and you can usually get several lengths of the stuff for free. Most of the time there are at least 50+ wires in the bundle with assorted colors. Just use the regular solid wire and avoid the twisted pair wiring. The good wire is ones that you can strip some insulation off with your nails by hand. If the insulation is really old and sticks making it hard to remove even with wire strippers than throw it out (better yet recycle it) and find some other source. You can usually get a lifetime free supply like this. They moved a PBX here at work and abandoned all the old thick runs that have tons of the solid wires in it. Needless to say I'm covered.
Robert
Paul Baker
I think I've hit on an accurate description for the PPDB, "A theme park for the Propeller" [noparse]:)[/noparse]
OBC
Post Edited (Oldbitcollector) : 8/27/2008 8:01:47 PM GMT
@OBC-Paul's pic is the only cookie you deserve. You·already received·a PPDD!
Whit+
Post Edited (Whit) : 8/27/2008 8:14:55 PM GMT
"I'm leaving!"
www.fd.com.my
www.mercedes.com.my
