Transmit Stamp Data down 12 volt line
Isthere any info about on using stamp to transmit data down a 12 volt line (eg model railway track) to a stamp decoder at the end.
Just looking for info re the transmission of data, and setup codes.· Encoder and decoder I am ok .
Charlie
Charlie
If you needed there to be 12v running on the line, and send data on top of that, im not sure, other than maybe running a 13v signal on top of that, assuming it really was a train or something that wouldnt care about a little extra power.
If you just need to send data at 12v, just use a simple PNP transistor, hook 12v and wire to emittor and collector, and send a negative pulse to the base.
Thks
Charlie
Charlie
http://www.nmra.org/standards/sandrp/consist.html
These are the standards that the model railroad industry uses for the manufacture of model railroad components, including DC and DCC. They might give you some ideas on how to transmit the signal. Also, if you make sure your system is compatable with these systmes then you don't need to worry about your system suddenly ceasing to work if you introduce a new component to the railroad.
Tracy Allen
www.emesystems.com
However, it DOES require a centralized unit to generate the pulsing AC signal, and it does so with a few amps behind it. Any 'competing' signal could be swamped, or could result in DCC equipped engines NOT getting their signals.
Now, the "normal" system is DC controlled (which sounds like what you're talking about). This system is quite electrically "noisy", but you COULD capacitively couple signals onto the track (as described by Tracy above).
The usual BS2 based systems I've seen documented, solve this problem by running their own signal wire around the layout under the table. This gets you past the "variable DC" and "noisy signal" problems.
