The spector of EMF
I need to trigger two solenoid valves (110V at 8W) on a pneumatic system I'm building.
I have a BASIC stamp outputting +5V to the base of a set of two transistors set up in a Darlington array.
Then I have the Emitter/Collector being the neutral for a SPST relay's coil. (I have a 1N4003 flyback diode across the contacts of the coil)
I think this is very similar to the diagram in Nuts and Volts column 6. However, I have an issue:
When My program reaches the point when it is supposed to continuously alternate between the two solenoids,
it fires the solenoids for about 4 alternations and is then somehow kicked into the beginning of the code again
to my 'WATCHDOG' loop of a blinking LED.
I think I've eliminated everything program-wise that could cause such an issue. Is it possible that,
although I have a flyback diode and Darlington array, that there is some sort of flyback still disrupting the stamp?
check your code for a MISSING "RETURN" or "GOTO" that ends in a dead routine. that can be the reason for reset.
Hope to help
Amaral
What happens if you place an external 1K resistor across the ATN and VSS?
Many years ago, I made an industrial blower/vacuum system (240VAC) controller that had similar problems.· but I had left a custom very long
30 foot programming cable connected to the unit that acted like an antenna.
Placing a resistor across the ATN and VSS, made the BS2 less susceptible to "resetting" itself from noise.
Beau Schwabe
IC Layout Engineer
I have a 5V DC wall adapter that isn't regulated (it puts out about 5.16V).
This led me to put the 5.16V through the regulator, which did run it, but maybe it does brown out.
I'll try replacing it with a 6V or so...
More recent voltage regulator designs have a lower drop out voltage. With some it's as low as 1/4V at low currents (50mA).
