Random generator
I was wondering if the Basic Stamp has the capabilaty to be used as a random number generator? Cause in the book it can count up and down. So if it can how would I program it to do so?? I want it to use the debug screen of course
Thank you
Lutamos ^_^
Thank you
Lutamos ^_^
See the PBASIC RANDOM command. As SRLM mentioned it's "pseudo-random"; but its statistics are good, and it truly is adequate for most applications requiring random numbers. Here's a scatter chart that graphs values from RANDOM, each paired with its successor. Notice the apparent lack of correlation between the two:
Post Edited (Phil Pilgrim (PhiPi)) : 8/26/2008 4:00:11 AM GMT
If you need only two or three numbers, the RANDOM command might work if you change the seed value. The question the goes into a sort of recursion: how do you get a random number to provide the seed value? You're back where you started.
Phil Pilgrim: have you heard about phi being the most random of numbers? I've only looked at one source, but it's pretty exhaustive on the subject.
Also, most Stamp apps don't require all 16 bits of a random number. The remainder operator can be used to reduce the domain of numbers generated. When limited this way, the successor to a given number will not always be the same.
SRLM, there's really no such thing as "a most-random number". Numbers are only random when considered in a sequence with other numbers. Randomness has to be analyzed statistically, and one number doesn't make up a statistically-significant sample.
'Still some PropSTICK Kit bare PCBs left!
the random numbers in the scatter chart? Thanks.
humanoido
A quote, pg 84: "
1 + 1/(1 + 1/(1 + 1/(1 + 1/(...))))
This is a special cse of mathematival entities known as continued fractions, which are used quite frequently in number theory. How would we compute the value the value of this continued fraction? ... we could at least start by denoting the value by x. Thus,
x = 1 + 1/(1 + 1/(1 + 1/(1 + 1/(...))))
Note, however, that because the continued fraction goes on forever, the denomintator of the the second term on the right-hand side is in fact identical to x itself. We therefore have the equation
x = 1 + 1/x
Multiplying both sides by x, we get x^2 = x +1, which is again the equation defining the Golden Ratio! We find that this remarkable continued fraction is also equal to phi. ... Because the continued fraction corresponding to the Golden Ratio is composed of ones only, it converges very slowly. The Golden Ration is, in this sense, more 'difficult' to express as a fraction than any other irrational number - it is the 'most irrational' among irrationals."
A little off topic from randomness, but interresting never the less...
Post Edited (SRLM) : 8/26/2008 10:52:03 PM GMT
' {$STAMP BS2} ' {$PBASIC 2.5} W1 = 32767 FOR W0 = 1 TO 1000 W2 = W1 RANDOM W1 DEBUG DEC W2, " ", DEC W1, CR NEXTThe results were copied from the DEBUG screen and pasted into Excel, where the graph was created.
The golden mean is also very fascinating also. it's proportion can be found every where in nature and even in the human body. If you want a good looking bot build it to the golden Ration! how does this help you generate a random number... it doesn't
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
X(k+1) = X(k) + m mod (2^n)
where n is the word size (16 or 32 bits), and m is the phase advance per cycle. k is an integer 1,2,3,....
The output is a sequence of phases on a scale from 0 to 2^n.
The two graphs below compare the phase sequence when m=40503 versus m=20861, and a word size modulus of 65536. Why those numbers? 65536/40503 is a close integer approximation to the golden mean, phi, while 65536/20861 is a close integer approximation to Pi. It can be seen that in a sense the sequence for Phi is more random than the sequence for Pi. In practical terms for direct digital synthesis, the Phi sequence has far more subharmonic jitter in its frequency output and in fact Phi is the "worst" in that respect. This is related to the small coefficients of the continued fraction expansion of Phi=(1,1,1,1,....) compared, say, to the large coefficients of the continued fraction expansion of Pi=(3,7,15,1,292,...).
That does not make X(k) from Phi a good source of psuedo-random numbers. In fact they are awful and flunk almost all statistical tests. Much better generators are "conguential sequences" of the form,
X(k+1) = a*X(k) + c mod (b)
where the multiplier "a", the additive constant "c" and the modulus "b" are carefully chosen. The modulus b may be 2^n or 2^n-1. There are many other generators. While the digits of Pi in any base pass tests for randomness, they are not easy to compute.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 8/27/2008 4:47:02 PM GMT
