is the homework board different from the oem stamp??
i have a homework board that works great but tried the oem basic stamp 2, hooked up to the same usb to serial converter and get "no stamp found".. i do get loopback and echo, but no stamp.. im thinking tha maybe the circuit on the homework board is different from the oem bs2.. or i might have ruined one of the transistors?? anyone else had this problem?? i have checked my soldering and all looks well, what should i check next?? thanks ahead of time..
Remember, the homework board has those good/bad 220 ohm resistors in series with all the IO pins. Sometimes those affect your external electronics.
ok checked and rechecked solderjoints all seem ok.. went through with continuity tester and all lines seem to get where they need to.. guess all that is left is to get a straight thru serial cable and try that way.. must be that the oem circuit is a bit more restrictive than the circuit on the homework board... maybe my usb to serial cable is getting just barely rs232 compliant signal and oem circuit is lookin for a well within rs232 compliant signal?? stop me if this is a foolish idea...
Post Edited (kb1nrb) : 8/25/2008 8:31:41 PM GMT
Are you using a different converter?
Edit: KC9KST here.
Post Edited (sylvie369) : 8/28/2008 3:28:52 AM GMT
Chris Savage
Parallax Engineering
Are the parts in proper location AND orientation? You can check the transistors with a multimeter, per http://www.electronics-radio.com/articles/test-methods/meters/multimeter-diode-transistor-test.php··The brown out detector is cheap to replace http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/ProductID/387/Default.aspx?txtSearch=oem+bs2&SortField=ProductName%2cProductName
and it looks like you can test it to see if it's pulling the reset line low (incorrectly). If it is fried and pulling reset low, you could remove it temporarily and pull reset high with a pullup resistor ~10K. Meanwhile, make sure your Vdd is getting everywhere it's supposed to all over the board, including the reset line.
Also check your resonator for proper orientation.
erco km6ds
Post Edited (erco) : 8/27/2008 5:03:39 AM GMT
Chris Savage
One thing you might check·is the·IC chips for bent pins this has happen to me more than once
The reason·I say this unless you take the chips back out you may not see it
if pin or pins are bent under the chip
Just an ·
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/29/2008 11:37:06 PM GMT
