Weid spin code behavior
Hi All,
I have modified a version of ADC.spin that takes two pin arguments as well as the return value in order to use the object with multiple channels of sigma delta hardware.
That code works fine. I have also added a cog stop method so that I can re-use the cog.
However, my problem is with the following code that calls the ADC_brm.spin object. . The 1st call to GetPot() works fine and I can access both sets of hardware if I change the Pin arguments. However calling the second call to GetPot() after the 1st
(they have the pin asignments shown) produces the same result for each. i.e. the "y" result is the same as the "x" result, "y" is incorrect.
I have stared at this code forever and can not see what is wrong. Can someone please have a look and tell me what the problem is?
Bernie
Bernie
PUB go | x, y CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 txpin = 30 rxpin = 31 SDF_0 = 3 'sigma-delta feedback SDI_0 = 7 'sigma-delta input SDF_1 = 5 'sigma-delta feedback SDI_1 = 0 'sigma-delta input VAR long avg OBJ adc : "ADC_brm" uart : "FullDuplexSerial" PUB go | x, y uart.start(rxpin, txpin, 0, 115200) repeat x := GetPot(SDI_0, SDF_0) uart.str(string(13,11,"Pot0 = ")) uart.dec(x) y := GetPot(SDI_1, SDF_1) uart.str(string(", Pot1 = ")) uart.dec(y) PRI GetPot (sdipin, sdfpin) : sample sample := 0 repeat 16 ' average 16 samples adc.SigmaDelta(sdipin, sdfpin, @avg) sample += avg adc.stop sample >>= 4 sample -= 5240
Please check the way I have passed the pin arguments to the assembly function ..
1. The repeat 16 loop tries to start a cog each time round the loop which will fail and probably isn't what you want
2. The adc cog takes some time to run and output a result. The main cog doesn't wait for it to generate a result so the results could be anything, try
This starts the adc cog once per get pot and forces a delay until the adc cog has generated a result each time round the repeat 16 loop. It does have a problem if the possible output is 0, if so you could change avg := -1 and check for <> -1 instead
Post Edited (Timmoore) : 8/22/2008 7:25:20 AM GMT
Thanks. I should have seen that I was starting 16 cogs .... good pick up.
Waiting for the conversion to finish I didn't even think about, must get used to things running in parallel
I will try your code out ..
Cheers,
Hi Tim,
I have tried the code and am seeing the individual channels, but am still getting some weid results.
With the averaging loop commented out so that I can see the return value, I am getting a result, but I have to subtract a large
offset value (see code below) before I get my 0 .. $1024 result for 0 .. 3.3v in. ( A2D set for 12 bits.
Can anyone tell me why there is this offset?
Looking at the adc code there looks to be a bug the first time, asm_old is not initialized so the 1st output value will be incorrect, if that is what to are getting this it will be wrong. The value of asm_old will be always the same, it will be loaded from the hub memory so depends on what follows in the code.
The original adc.spin looks to have hte same problem.
If the first value has the problem but the 2nd, etc dont, then add a mov asm_old,#0 after the mov frqa,#1 line
The problem was in the original adc.spin code. After initializing the asm_old variable at the start every thing works fine.
How do we report bugs for objects in the exchange?
Bernie
