Programming the SX without a key
I'm a propeller user and would like to learn about the SX a little, yet I know very little at the moment. I know there is a simple circuit you can make to program the SX with an RS232 cable - no need for a prop plug. I ordered some SX chips, but totally forgot the SX key. Can I still program it without the key?
programming voltage.
regards peter
regards peter
Greetings from Germany,
G
AS Guenther mentioned, the Blitz is a cheap alternative at $29:
www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/ProductID/368/List/1/Default.aspx?SortField=ProductName,ProductName
The only issue is that it will program the chips, but you can't do hardware debugging with it. However, Guenther's SX-Sim simulator program, which comes free with the free SX-Key IDE, will let you debug the code via simulation.
This link is to the SX-Key IDE:
www.parallax.com/Portals/0/Downloads/sw/sx/Setup-SX-Key-Editor-v3.2.3lg.exe
PeterM
