Lowest Cost H-Bridge
I need to control a small motor (0.5 amps) and also make it reversible.
Most H-bridge ICs I can find cost more than the motor itself.
Any low cost recommendations?
Can I use a ULN2003 IC to make a h-bridge?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
Forum member erco posted a sketch a while back if you're looking for a schematic.
Cheers,
Tom Sisk
http://www.siskconsult.com
http://www.solarbotics.com/products/k_cmd/
http://www.parallax.com/Store/Accessories/MotorServoControllers/tabid/160/CategoryID/35/List/0/Level/a/ProductID/491/Default.aspx?SortField=ProductName,ProductName
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
You can't build an H-bridge from a ULN2003, since it's current-sinking only. An H-bridge consists of two current-sinking and two current-sourcing drivers. If you're designing for mass production, the cheapest way to go is probably discrete transistors: 2 PNPs and 2 NPNs (or their MOSFET equivalents) with associated resistors and diodes. Zetex makes some H-bridge transistor arrays that might make nice building blocks. The web should be replete with candidate circuits. You will want to design in some current limiting as a protection against short circuits, as well as protection against cross-conduction, which will fry an H-bridge.
The cost is 6 transistors and two resistors.
http://www.solarbotics.net/library/circuits/driver_tilden.html
The web site has instructions on how to 'free form' the wiring so you don't need any printed circuit board.
This is not the cleanest or most efficent design and if you want to have better power usage, you have to add a few more resistors and a couple of diodes.
If you have space on a board [noparse][[/noparse]like the SX-28 Proto board or the Propeller Proto board], you can mount your compontents with your processor.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Post Edited (Kramer) : 8/21/2008 8:34:49 AM GMT
H-Bridge Motor Driver 1A
sku: COM-00315
Description: Faster, cheaper, smaller, better, right? The SN754410 Quad Half H-Bridge is just that. Capable of driving high voltage motors using TTL 5V logic levels, the SN754410 can drive 4.5V up to 36V at 1A continuous output current! Please see datasheet for more information. This is a pin to pin compatible replacement for the L293D.
http://www.sparkfun.com/datasheets/IC/SN754410.pdf
BTW, something I learned just last week: have your stuff shipped from DigiKey by Priority Mail. It's faster and way cheaper than UPS, and you can get your stuff on Saturdays, too.
'Still some PropSTICK Kit bare PCBs left!
http://www.hobbyengineering.com/appHBridge1A.html
Ted
