Piezo Film Vibra Tab Mass Vibration Sensor
Hi,
My name is Jordan Krell and I am from Plankinton, South Dakota.· I am starting a project and to reach my goal I need to be able to sense and read the vibrations that an object outputs.· I purchased a LDT0 vibration sensor from Parallax (the Piezo Film Vibra Tab Mass).· In the information sheet, it is specified how to use it as a triggering device but I would like to use it to measure the vibrations and not as a triggering device.
··· In the application note from the manufacture, it describes how to use it as a vibration sensor and states that a charge amplifier is needed for this.· My first question is what is a charge amplifier or how is one constructed and secondly, is one neccessarily needed?· Thank you very much and have a great day!
Jordan M. Krell
Jordan M. Krell
The sensor is like a small capacitor and when it is flexed, a small amount of charge is generated in the piezo plastic . The charge collects on the electrodes plated on the opposite sides of the plastic and makes a voltage. The movement of charge is also small current, so if the electrodes are shorted, that current flows from one plate to the other. The current (or voltage) alternates + and - depending on the direction of flex. The sensor can be hooked up in an op-amp circuit that amplifies the current or the voltage. A charge amplifier integrates the current with another capacitor in the feedback path, and that can be made very sensitive and proportional to the time course of charge generation in the sensor.
Tracy Allen
www.emesystems.com
Jordan
10kΩ potentiometer set ~1.4 volts for high sensitivity. +5 ---/\/\/\/\/\/\------ Vss | 10 MΩ `---/\/\---o----- p0 | ===== | Vss DO COUNT 0,1000,result DEBUG DEC result,CR LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Tracy Allen
www.emesystems.com
