C++ Exception Error when I Complile
Hello-
I am using the IDE Version 2.0.3 with my Javelin Stamp and the Ping Sensor. I have written a .java file that compiles fine, except gives me this popup error message of "C++ EXCEPTION" and will not download. I am calling a Ping.class file < import stamp.peripheral.sensor.range.ping.*; > in my .java program. The Ping.class file is in the ping folder. I think that I don't have the right code in my class file- can you guys supply that?? I have attached my .java program (which previously worked, I am changing computers and lost my class file so thats where i believe the problem is) and also attached my Ping.class file. I am very new this this whole thing so please don't overlook simple solutions! Thanks so much for your time.
regards peter
Then you can program·your runMotors2.java into the javelin.
regards peter
