Prop Plug Not Working
william chan
When I plug in my brand new Prop Plug into my notebook USB port, both LED light up continuously, but no serial ports were found.
So, I pull out the Prop Plug and tried a SX Blitz instead using the same USB cable, COM4 appeared.
I pull out the SX Blitz and plug in the Prop Plug again, now both LEDs do not light up. No serial ports appeared.
I am using the latest FTDI USB drivers.
Is the Prop Plug dead? It is totally new and unused.
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
I'm not sure exactly how it happened but, Yesterday I had a propeller chip that died. I'm using the 40 pin DIP chip on a breadboard, with the prop plug for programming. I have been using this set-up for the past several months without any problem, until yesterday. Very suddenly, the propeller "could not find...on Com port..." (or something close to that message). After verifying everything was still wired correctly, I swapped chips, and now the new chip is working fine.
I'm not sure exactly how it happened, but the old chip is now dead. I practice ESD control, and I don't think I did anything that would damage it.
Good luck
'Still some PropSTICK Kit bare PCBs left!
When I release the pressure on the FTDI chip, the com port stays there.
Each time I plug in the Prop Plug, I need to put some pressure on one side of the FTDI chip to get a com port to appear.
Anybody experience this phenomenon before?
www.fd.com.my
www.mercedes.com.my
If you have another propeller chip, swap the chips and see if you get the same results with the 2nd propeller; If you do get the same results, your prop plug is most likely bad (Based on your description, I suspect the prop plug). If the 2nd chip works normally, it's probably the chip itself thats bad
Similar. The joints holding the USB connector on my prop plug were all dry. it started out intermittent and eventually just fell off the board..
Nothing a fine point iron and some lead based solder could not fix though. It'll be a bit harder if a joint under the FTDI chip is dry though.
Pull my finger!
Paul Baker
