Anyone familiar with ISD25xx family ???
wonder if anyone is familiar with the isd voice recorder chip ?? question is can i record to a specific address or is it always sequencial?? putting together a radio voicemail system for use on vhf radio.. iwould like to have a prerecorded greeting, but want it at the end of memory to avoid accidental overwrite.. i could put it at address 0
but then i would still need to know how to start recording messages at address 1 keeping my greeting intact.. future upgrades might include a rtc chip with time reported in my voice and maybe a ds1620 outside the shack to report current temp.. the rtc and 1620 could share 2 stamp pins using a whopping 4pins between the two.. they could also use the same prerecorded digits!! anywho i ramble off topic.. back to my ?... can i record to a specified address without recording to all the rest on the way?? i would use the isd sound lab from nutsnvolts volume 66 to figure it out so if you have suggestions it would be best to refer to that code..
Chris Savage
Parallax Tech Support
http://forums.parallax.com/showthread.php?p=659734
I have the 25XX chips also, and I remember they are waaaaay easier to use than the 40XX series. If I remember correctly, you simply record and it keeps track of how many items you have. Each new sound gets a number, 1..2..3 etc.
I'd make your permanent recording the FIRST thing on the chip, then record all other sounds after that. If one of your recordings uses up the available memory, you won't overwrite your first message. All you need to do is send it the number or address of where you want it to start recording. Basically, select the first sound, then use the skip command to jump to the end of the sound bite, and start recording. In the specifications sheet, you are looking for the M4 command, consecutive addressing.
You can always take the same approach I used... and create an index of where the sounds are(on the 2560 chip) and save them to an EEPROM. You can easily save the info to a 24LC16B, then you can skip around an record where ever you want. If you choose this apprach, simply record the starting address where you are going to store the·sound, after it records, store the current address as the ending address. The next sound will be recorded one byte past the end of the last address.
Next, take a look at this book, it has the plans and code for doing the project you are talking about. It uses a BS2, but translating the code is very easy. I don't have the book in front of me, but I think he is using the 25XX family of chips to record the sounds.
Stamp 2 Communications:
http://www.amazon.com/STAMP-2-Communications-Control-Projects/dp/0071411976/ref=sr_1_3?ie=UTF8&s=books&qid=1218666440&sr=8-3
Take care,
Dan
Post Edited (DosManDan) : 8/13/2008 10:28:10 PM GMT
Using the M commands for the ISD 25XX chip, you can use the skip command to walk through the recorded sounds. When you skip to a sound, you can then issue a command to read the address. This is useful if you ever need to rebuild your index.
Check the interface again, I don't believe you need to use all the pins for the address. Only pins A0(M0), A6(M6), A8 and A9 are connected to the chip. The others all connect to ground. Basically the first 7 are used to select playback modes and setttings.
Dan
http://forums.parallax.com/showthread.php?p=553075
tim: great project, i cant wait till i get more familiar with bs2, then ill be confident about moving up to either the sx or prop.. for now the bs2 is keeping me very busy.. like ham radio and my bike this "hobby" is quickly becoming a habit..
