Beagle Board vs Super Propeller Board II
http://dkc1.digikey.com/us/mkt/beagleboard.html
Is like a war among manufacturers. Price war and characteristic:
- 600MHz ARM Cortex-A8 (>1GHz ARM11 MIPS)
- 128MB low-power DDR RAM
- 256MB NAND flash
- Full Linux Computer
Linux distributions
Angstrom (Open Embedded), Debian, Ubuntu, Gentoo, and more
User mode applications
Productivity: AbiWord, Gnumeric, GIMP
Multimedia: FFmpeg, MythTV
Gaming: ScummVM, solitaire
I ask me which will be the real capacities of the Propeller 2, price, etc.
And more important ¿When will I put my hands on one?
- 256MB NAND flash
Linux distributions
http://propeller.wikispaces.com/Propeller+II
I'd use the Processor for Linux, and the Propeller without Linux.
Beagle doesn't have Ethernet on-baord, but it does have auido/video. I've heard the beagle HDMI isn't really HDMI compliant though.
I don't think beagle is Intel x86 compatible. IMHO life is much easier if you stick with an x86 embedded platform when doing Linux/Unix/xBSD. To run the full-up Linux flavors you listed for beagle, its ARM Cortex-A8 processor must have a hardware Memory Management Unit (MMU).
Soekris Engineering www.soekris.com and PC Engines www.pcengines.ch have nice x86 boards for the money, some are cheaper than beagle. No on-board video or audio though. But I have used a serial LCD and USB audio dongle with one of the Soekris boards (NET4801-50). Running Linux or xBSD (for example) off a CF card in a RAM file-system is a neat solution for these boards. Some Soekris boards have an IDE port, I think both Sokris and PC Engines (Alix) boards have mini-PCI slots (nice for WiFi cards), compact flash slots, serial ports, USB etc. Have a look at the links above.
If you're looking for a long term commercial production solution be careful with PC Engines they're in Europe; and although it hasn't happened yet as far as I can tell, you might see them having to increase prices at some point due to the falling US Dollar. I wouldn't blame them for doing so. Soekris is in California. Direct support is much better from PC Engines. There is an active mailing list community for Soekris. I wish both manufacturers would put up a proper user forum.
Speaking of commercial applications, I've found a stumbling block to using propeller commercially may be a lack of intellectual property protection (IPP). I don't know if propeller-II will address this. I don't think it is addressed in beagle hardware but can be addressed in Linux.
Good Luck,
David
Post Edited (Drone) : 8/12/2008 11:23:01 AM GMT
It's right tool for right job, there's no 'that's better than this' except for specific applications or particular fields.
Its a nifty board and very reasonable at the price considering the serious computational punch it packs and the included software. Also TI was smart IMO marketing it directly at the open source community like that.
And go with what Virand says about the processor differences. The Prop and Beagle board are totally different animals, can't compare'em.
