Problem with propeller chip.
I got the chip. I put the vga and ps2 ports on. I put the 100 ohm and 470 ohm resistors and the headers and the jumper block. I hooked up to the ac adapter and the usb port on my xp machine. I ran prop startup tool as suggested. It said it could not find com port 1. When I hooked it up to my computer through the usb port, it made a little sound and red and blue lights beeped and blinked. After that I changed the port from 6 to 1 and tried different numbers but it did the same thing. "no propeller chip found on any com port.
I could use some help. Thanks in advance.
If you have an FTDI-based USB to serial adapter, download the current driver from FTDI's website and install it after uninstalling any existing driver.
You can delete messages that you post. Use the X box in the upper right hand corner of the message box.
My ride is here for church. Talk later.
READY.rminal FemtoBasic 2.004. is what I get. When I hit the arrows or the enter key, it just enters AAAA EEE, etc.
any idea?
This is on the protoboard.
