USB Datalogger help
Hi,
I am trying to learn to use the USB Datalogger (Vinculum) and need help with a couple i/o issues. DataloggerDemov1.0.bs2 and DataloggerTestV1.1.bs2 both run fine on my BS2.
I know so far that sending SEROUT TX\CTS, Baud, [noparse][[/noparse]"FWV", CR] will cause the Datalogger to return the FTDI firmware version (using this data merely as a test). I can't figure out how to actually get the data back to display in debug or on an LCD. I've used SERIN in attempts to get the data but after numerous failed iterations I'm left with no code and back at square one.
Once I have a grasp on the fundamentals of "talking" to the Datalogger, I'm confident I'll be able to do with it what I want. However, I'll soon need to figure out how to properly receive approx. 8k serially, write it to the Datalogger, and vice-versa. Yikes! (any advice in-advance?)
I would really appreciate any help I can get.
Many thanks.
Daniel Osterday
Many thanks.
Daniel Osterday
Thanks again. Dan.
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] I/O Definitions ]
' free are 8,9,10,11,12,13,14
LCDpin PIN 15 ' LCD output
USB_TX PIN 4 ' USB Transmit Data --> 27937.4 (RXD)
USB_RTS PIN 5 ' USB Request To Send --> 27937.6 (CTS)
USB_RX PIN 6 ' USB Receive Data <-- 27937.5 (TXD)
USB_CTS PIN 7 ' USB Clear To Send <-- 27937.2 (RTS)
[noparse][[/noparse] Constants ]
Baud2400 CON 396 ' 2400 baud
Baud9600 CON 84 ' 9600 baud
Baud19200 CON 32 ' 19200 baud
cursHome CON 1 ' common commands
clrLCD CON 12
rArr CON 126
lArr CON 127
[noparse][[/noparse] Variables ]
bPort VAR INA ' buttons port
btns VAR BYTE ' debounced inputs
btns_state VAR BYTE ' button input state
idx VAR BYTE ' loop counter
timeout VAR BIT ' USB timeout indicator
buffer VAR BYTE(15) ' USB input buffer
index VAR BYTE ' USB index variable
ioByte VAR BYTE ' USB i/o storage
[noparse][[/noparse] LCD Initialization ]
LCD_Init:
HIGH LCDpin ' initialize LCD transmit line
PAUSE 100 ' pause for serial LCD to initialize
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$16,$0C,$11] ' LCD cursor off, clear display, lamp on
PAUSE 5
[noparse][[/noparse] Main Code ]
GOSUB USB_Init
PAUSE 100
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$0C] ' clear the LCD
PAUSE 5 ' 5ms pause after clearing LCD
' ***** MY TROUBLE SPOT START *****
GOSUB Purge_USB_Buffer
SEROUT USB_TX\USB_CTS, Baud9600, [noparse][[/noparse]"FWV", CR] ' transmit "FWV CR"
PAUSE 200
GOSUB Get_USB_Data
SERIN USB_RX\USB_RTS, Baud9600, 800, No_USB_Data, [noparse][[/noparse]buffer]
SEROUT LCDpin, Baud19200, [noparse][[/noparse]buffer]
' ***** MY TROUBLE SPOT END *****
END
[noparse][[/noparse] USB Drive Subroutines ]
USB_Init:
PAUSE 3000
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$BC,"Initializing"]
HIGH USB_TX
LOW USB_RTS ' take vinculum out of reset
PAUSE 5000
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$BC,"Synchronizing"]
PAUSE 4000
GOSUB Purge_USB_Buffer ' purge USB buffer
index = 0
DO WHILE (index < 1)
PAUSE 500
SEROUT USB_TX\USB_CTS, Baud9600, [noparse][[/noparse]"E", CR] ' transmit "E CR"
GOSUB Get_USB_Data ' get returned data
LOOP
PAUSE 500
SEROUT USB_TX\USB_CTS, Baud9600, [noparse][[/noparse]"e", CR] ' transmit "e CR"
PAUSE 500
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$BC,"Testing Memory"]
PAUSE 500
SEROUT USB_TX\USB_CTS, Baud9600, [noparse][[/noparse]CR] ' transmit CR
GOSUB Get_USB_Data ' wait for
IF (buffer(0) = "N") THEN
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$BC,"Memory Error "]
STOP
ELSE
PAUSE 250
ENDIF
RETURN
Purge_USB_Buffer:
timeout = 1 ' set USB timeout indicator flag
DO WHILE (timeout > 0) ' while USB timeout has not occurred
PAUSE 50
SERIN USB_RX\USB_RTS, Baud9600, 500, No_USB_Data, [noparse][[/noparse]ioByte]
LOOP
RETURN
Get_USB_Data:
index = 0 ' initialize USB index
ioByte = 0 ' clear USB temporary storage
SERIN USB_RX\USB_RTS, Baud9600, 100, No_USB_Data, [noparse][[/noparse]ioByte]
buffer(index) = ioByte ' save byte received to array
index = index + 1 ' increment index
IF (index > 14) THEN ' check For overflow
index = 14 ' prevent overflow
ENDIF
LOOP
RETURN
No_USB_Data:
timeout = 0 ' clear USB timeout indicator flag
RETURN
Take a look at the code that I used for a project. It's in Completed Projects under the title Swiftsure BS2e Robot. You could tanspose that dirrectly to a BS2, minus the SCRAM and slot stuff.
Thanks for the invite to your robot code but - unless I missed something - I didn't see any useful SERIN stuff in there.
Do you/anyone else have any further advice?
Dan
The first SERIN Command is for a three digit number, the next SERIN expects 12, and so on. I found this to be very important. Keep·in mind that it helps if you know the format of your input file. I suppose that it's possible to interpret it real time with the BS2, but if you have a reasonable format all set out you can eliminate that.
Dan
' {$STAMP BS2}
' {$PBASIC 2.5}
' *** prefer using pin 0 as LCD instead. see var INA commenting below.
clrLCD CON 12
rArr CON 126
lArr CON 127
' *** INA defined here but pins 1,2,3 are the only one used. how to redefine pin 0 as
' the serial LCD pin instead of pin 15?
' *** how inefficient is this? the only reason for var ftdi is for proper re-display
' *** on LCD. prefer utilizing SERIN more effectively to not need var ftdi.
devinfo VAR WORD ' versions etc.
ftdi VAR devinfo.BYTE1
LCD_Init:
PAUSE 5
Splash:
GOSUB USB_Init
GOTO Main_Menu1
Main_Menu1:
PAUSE 100
PAUSE 5 ' required 5ms pause after clearing LCD
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$BE,lArr,$C5,rArr,$CC,"OK",$80] ' left, right, OK menu buttons. return home
SEROUT LCDpin, Baud19200, [noparse][[/noparse]CR,"main"]
' *** is this necessarily the best way to create a three-option menu?
DO
GOSUB GetBtn
IF btns = %0001 THEN Device_Info
IF btns = %0010 THEN Device_Info
IF btns = %0100 THEN Device_Info
LOOP
Device_Info:
PAUSE 100
' *** an error occurs here which prevents INA from working as buttons
' *** this code itself works, aside from the other problems it created
SERIN USB_RX\USB_RTS, Baud9600, 800, No_USB_Data2, [noparse][[/noparse]STR devinfo\16]
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$CC,"OK"] ' OK menu button
' *** start part 3 / this seems really inefficient to me but it works.
' *** see var ftdi commenting above
SEROUT LCDpin, Baud19200, [noparse][[/noparse]$80,"DEO 01.00",$97,STR ftdi,$94,"FTDI"]
DO
GOSUB GetBtn
IF btns = %0100 THEN Main_Menu1
LOOP
END
[noparse][[/noparse] Button Subroutines ]
GetBtn:
btns = %0111 ' enable all four inputs
FOR idx = 0 TO 2
btns = btns & ~bPort ' test inputs
PAUSE 15 ' 15ms delay between tests
NEXT
RETURN
USB_Init:
PAUSE 3000
HIGH USB_TX
PAUSE 5000
PAUSE 4000
index = 0
PAUSE 500
LOOP
PAUSE 500
PAUSE 500
PAUSE 500
STOP
ELSE
PAUSE 250
ENDIF
RETURN
Purge_USB_Buffer:
PAUSE 50
LOOP
RETURN
Get_USB_Data:
ENDIF
LOOP
RETURN
No_USB_Data:
RETURN
No_USB_Data2:
DEBUG CR, "Error reading the seed file -- Halting execution!", CR
PAUSE 1000
GOSUB Purge_USB_Buffer ' Purge Buffer
STOP
RETURN
btns VAR Nib
DO WHILE btns=0
btns=INA>>1 & 7· 'shift the 4 bits right 1 place and filter the relative 3 bits (P1 2 & 3)
LOOP
ON btns GOSUB no_task,task_1,task_2,task_3
I scanned your listing real quickly I hope this along the right lines
Jeff T.
