Has anyone seen any problems with the PIR in a warm room
I'm planning on using it in a room that might hit 120F during the day. I understand it determines changes in IR, but does anyone know if it heat soaks/blinds at some temp?
Chris Savage
Parallax Tech Support
Tracy Allen
www.emesystems.com
I'll try it on a hot day and post the results.
Thanks to all.
The first time we tried this was in an abandoned house at Pt. Reyes Nat. Seashore. The house had been boarded up for years and was straight out of the Adams Family. I was inside with the PIR sensors mounted on a window frame, and hooked to an oscilloscope. And a biologist with night vision goggles and an IR iluminator was outside to do a visual count. It was spooky to see the little blips on the 'scope as bats passed by. But I did live to tell.
Under ideal conditions of a straight across motion, the pulse is biphasic, with a positive peak followed by a negative peak for one direction and the opposite phase for the opposite direction. My original plan had been to decode that into a direction of motion counter. But the pulses in reality were hardly ever ideal. The bats would circle or fly at an angle and the pulse could take any shape whatever. So we ended up with a counter correlated to activity but not an exact count. The circuit was built from a chip PIR sensor and op amps, with a large IR lens.
Tracy Allen
www.emesystems.com
