Detection distance with the Infrared Receiver from Parallax an SX.
Hi,
I need to increase distance using the Infrared Receiver
(Item code 350-00014) with the Parallax IR emitter.
When I use that sensor with a Basic Stamp I can detect
an object at about 3 feet (max) , but the same sensor
with the SX 28 is about 2 inches only.
How can I increase this distance using SX28 microcontroller?
Thanks, Mark
PS:
Please see the rutine:
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
PROGRAM Start
INI:
DO
FREQOUT RB.1, 10, 38000 'RB.1 OUT LED IR
IF RB.2= 0 THEN 'RB.2 OUT from sensor IR
HIGH RB.0 'RB.0 LED INDICATOR
PAUSE 500
LOW RB.0
PAUSE 500
ENDIF
LOOP
Thanks, Mark
PS:
FREQ 4_000_000
PROGRAM Start
INI:
DO
PAUSE 500
LOW RB.0
PAUSE 500
ENDIF
LOOP
[noparse][[/noparse]Edit] The datasheet is right on the Parallax page for that part (PNA4601M), and according to it the modulation frequency is 36700.
www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/PNA4601M.pdf
Post Edited (JonnyMac) : 8/7/2008 5:17:22 PM GMT
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
I have made changes:
Now , the pulse is longer than 10millisecond ( I am using more than 10 i.e 15, 20, etc. )
and I am using different modulation frequencies but I have the problem yet.
Many thanks for you fast response and support.
Any way if you have an other idea about how can I increase the range
please help.
Thanks, Mark
I am using no resistor because I need to increase the detection range.
The same circuit works better using a Basic Stamp ( 3 feet)
but using SX28 is about 2 inches only.
Do you know why ?
thanks, Mark
PS: Please help.
FREQ 4_000_000
PROGRAM Start
INI:
DO
FREQOUT RB.1, 20, 38500 'RB.1 OUT LED IR
PAUSE 500
LOW RB.0
PAUSE 500
ENDIF
LOOP
Remember that modulation frequency affects detection distance. Your code is specifying the use of the internal RC oscillator which is not as accurate as the resonator used on the BASIC Stamp. Add a 20 MHz resonator to your circuit and change the setting to OSCXT2; this will give you the better accuracy with FREQOUT and a real chance to increase detection distance.
