float32full.atan help?
Hello all,
I am trying to use the floatlib library (float32full bits) to perform atans.
I don't get the answer back I expect compared with my calculator... Help?
This is what I am doing:
As return values I get
a1 = 1.282051 (correct)
a2 = 0.9083684 (I am expecting 52.04... degree's)
(note := I have seen the post regarding the atan table error - and have the latest code form obex.parallax.com I believe..!)
Cheers!
James
OBJ
float32 : "Float32full"
floatstring : "floatstring"
pub start
float32.start
' 5cm/3.9cm = 1.2820 = 52.04 degree's...!
answer1 := float32.fdiv(5.0,3.9)
answer2 := float32.atan(answer1)
debug.str(string("a1 ="))
debug.str(floatstring.FloatToString(answer1))
debug.putc(13)
debug.str(string("a2 ="))
debug.str(floatstring.FloatToString(answer2))
debug.putc(13)
debug.putc(13)
Cheers!
James
Try multiplying by 180 / Pi
Suspected it might be my maths!
For those interested - the fix is:
CON rad2deg = 57.29577 PUB Start float32.start ' 5/3.9 = 1.2820 = 52.04 degree's...! answer1 := float32.fdiv(5.0,3.9) answer2 := float32.atan(answer1) answer3 := float32.fmul(answer2,rad2deg) ' <------------- debug.str(string("a1 = ")) debug.str(floatstring.FloatToString(answer1)) debug.putc(13) debug.str(string("a2 = ")) debug.str(floatstring.FloatToString(answer2)) debug.putc(13) debug.str(string("a3 = ")) debug.str(floatstring.FloatToString(answer3)) debug.putc(13) debug.putc(13)results are now:
a1 = 1.282051
a2 = 0.9083684
a3 = 52.04567
Cheers
James
Post Edited (Javalin) : 8/7/2008 7:09:23 PM GMT
