Lack Servo Control
I am trying to build line following boe-bot. When BS2 read sensor value and instruct the motor to stop, motor not stop immediately. So, when motors stop, the sensor position has changed. How to control this precisely (when sensor read, motor stop immediately)? I want to stop the boe-bot when sensor found intersection or T.
Btw, any references or hints how to make line follower boe-bot with intersection and T?
Thanks in advanced.
--chris
Thanks in advanced.
--chris
Having two separate sensors at different distances from the BoeBot also gives you the opportunity to use the further sensor as a warning to slow down, then the closer sensor will tell you if you've gone too far and you can back up slightly to be in the position you want to be in.
Kemprof ,· Santa Ana High School
www.sahsrobotics.org
