Need Help with BS2 connected to a motor controller — Parallax Forums
BaldenBalden Posts: 4
edited 2008-08-07 00:32 in BASIC Stamp
Hi. I have a bs2 in a board of education. I want to program my RC car's Brush motor to run. I have a motor controller by NOVAK. It is the XRS sport reversible motor controller. I am not sure how to program the motor speed controller with the basic stamp 2. I can control the steering servo motor no problem however. Can someone help me? I added pics so you can get an idea. Thanks
  • BaldenBalden Posts: 4
    edited 2008-08-06 04:44
    Here is some practice code I tried. The motor turns on then slowly slows down. Then it barely moves and just makes noise. Can someone tell me what is going on? Any feedback or questions would help.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    speed VAR Byte
    HIGH 14
    LOW 15
    HIGH 15
    PAUSE 100
    FOR speed = 0 TO 127
    SEROUT 14,84,[noparse][[/noparse]$80,0,0,speed]
    PAUSE 20
    NEXT
    FOR speed = 127 TO 0
    PAUSE 20
    NEXT
    SEROUT 14,84,[noparse][[/noparse]$80,0,1,speed]
    PAUSE 20
    NEXT
    PAUSE 20
    NEXT
    edited 2008-08-06 05:42
    I think I have narrowed it down. Here is the million dollar question. A receiver inputs some impulses or logic to the motor controller which makes the motor accelerate, or decelerate or go reverse or forward correct? So, how do I mimic what a receiver inputs exactly for this device? I have researched and experimented and analyzed this problem and I still not getting my machine to operate very good. Hope to hear some good advice when I wake up. Thanks and good night.
    edited 2008-08-06 06:38
    Balden -
    Good analysis of the problem. You can mimic those pulses with the PULSIN and PULSOUT commands.
    Bruce Bates
    Involvement and committment can be best understood by looking at a plate of ham and eggs. The chicken was involved, but the pig was committed. ANON
    Post Edited (Bruce Bates) : 8/6/2008 10:06:52 AM GMT
    edited 2008-08-06 23:46
    Figuring out now the exact PWM that a reciever sends to the motor controller. For example, full throttle foward, and full throttle reverse. What would be the Pulse width, and Pulse duration?
    Well, it looks like it hooks up to the receiver like a servo so I would start with sending it pulses between 1ms and 2 ms with a pause between pulses of 20ms. This is what works for servos and you will have to test and adjust these valuse for your hardware but that should give you a place to start.
    - Stephen
