REV is driving me crazy
Well,
I'm now testing the FFT on a real propeller, so I wrote some help and test code. All looks good but the decimate routine.
Symptom: The REV instruction is not behaving as I think. Here is the routine:
I hope it is readable.
This should reverse the addresses from 1 to 1023 using the REV instruction.
As it is a REV something, #10 it means that it will not produce any number beyond 1023 (I tested it with some other program using the '><' spin operator, it looked ok).
Well: either with the second comparison or with the commented-out and or without them... I get different results ! This is very wired... And are the input values around 320 to 380 the ones that produce a wrong output (It does not show in spin !?).
Any idea ?
decimate mov fft_ii,#1
mov fft_ll,cnt_k1_1024 'fft_n
ldecimate mov fft_jj,fft_ii
rev fft_jj,#10 'BITS_NN
cmp fft_ii,fft_jj wc
if_nc jmp #ldecimate_5
' cmp fft_jj,cnt_k1_1024 wc
' if_nc jmp #ldecimate_5
mov fft_fr_ii,fft_ii
shl fft_fr_ii,#1
add fft_fr_ii,fft_fr
'and fft_jj,cnt_k1_03ff
mov fft_fr_jj,fft_jj
rdword fft_tr,fft_fr_ii
shl fft_fr_jj,#1
add fft_fr_jj,fft_fr
rdword fft_result,fft_fr_jj
'mov fft_tr,cnt_k1_mask
wrword fft_tr,fft_fr_jj
wrword fft_result,fft_fr_ii
ldecimate_5 add fft_ii,#1
cmp fft_ii,fft_ll wc
if_c jmp #ldecimate
decimate_ret ret
Any idea ?
REV Instruction: Reverse LSBs of value and zero-extend. REV Value, 〈#〉 Bits Result: Value has lower 32 - Bits of its LSBs reversed and upper bits cleared. • Value (d-field) is the register containing the value whose bits are reversed. • Bits (s-field) is a register or a 5-bit literal whose value subtracted from 32, (32 - Bits), is the number of Value’s LSBs to reverse. The upper Bits MSBs of Value are cleared. –INSTR– ZCRI –CON– –DEST– –SRC– Z Result C Result Result Clocks Result = 0 D[noparse][[/noparse]0] Written 4 001111 001i 1111 ddddddddd sssssssss Explanation REV (Reverse) reverses the lower (32 - Bits) of Value’s LSB and clears the upper Bits of Value’s MSBs. If the WZ effect is specified, the Z flag is set (1) if the resulting Value equals zero. If the WC effect is specified, the C flag is set equal to Value’s original bit 0. The result is written to Value unless the NR effect is specified.-taken from prop manual
specifically this bit:
you are reversing the lower 32 - 10 = 22 bits.
replace #10 with #22 to reverse the lower 10 bits(0 to 1023)
Hope this helps.
Lee.
Well, thanks again !
·· REV data,#upper· ' #upper is the number of upper bits to clear, and reverse the lower remainder bits
Shift left by x
Reverse the entire 32-bit number
lonesock
Piranha are people too.
The shifter in the Propeller is what's called a "barrel shifter" which does everything
all at once in one clock cycle. Every bit has all the logic to compute all possibilities for
shifts and shift counts.
I'm sure there's a good reason for clearing those upper bits. But it kills reversibility, and it makes it more
difficult to use rev to do some bit permutations.
(Indeed, it's a fun puzzle to consider using a variant of rev that *preserves* the upper bits to perform
arbitrary bit permutations; what permutations are the hardest (require the greatest number of
instructions) to obtain? This is known as the "pancake problem" and it was the subject of one of
Al Zimmermann's programming contests. By the way, there is one of the contests going on now on
recmath.org; they are usually a blast to participate in.)
