Documentation for old style gripper — Parallax Forums
BrendanTXBrendanTX Posts: 2
edited 2008-08-03 12:32 in Robotics
I cannot, for the life of me, find the documentation for the 28200 model gripper (This is the older version, with the ir detectors mounted on the sides of the panels.
Does anyone have a suggestion on where I could find a copy of said manual?
Thanks in advance.
  • WhitWhit Posts: 4,194
    edited 2008-08-02 23:53
    BrendanTX,
    Take a look here - http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/GripperManual-v3.0.pdf I think it is what you are looking for. It is the right model #, but I do not see the IR detectors.
    I found this using the improved Parallax Search that you can find at the top of the Support Using this Forum Section.
    Whit+
    Post Edited (Whit) : 8/2/2008 11:59:52 PM GMT
  • BrendanTXBrendanTX Posts: 2
    edited 2008-08-03 02:58
    I appreciate the attempt, but I already have that manual. I've managed to get most of it working at this point, but the servo pulses etc are still sketchy at best.
    Sorry that is not what you need. You might check with tech support - I'm sure they have the older documentation avaliable.
    Whit+
