Depth finder transducer
I have a dock on a lake that the water drops during the winter, and sometimes I have to move it.· I was thinking about setting up a PINK or Simple Lan to be able to track if the dock needs to be moved or not.
I know I can get sonar transducers, or digital depthfinders.· Has anyone successfully interfaced one of these devices to a Propeller or a Stamp?
End dependance on foreign oil.· www.pickensplan.com
http://www.cocoontech.com/index.php?showtopic=4419
Also, each year when the water is down, I try to dig down and remove rocks to get my dock more clearance, but when the water fills up in the spring, silt and shale fills up (the picture is my last digging effort).· So it would nice to have an actual measurement rather than checking the lake level each day.· When I dug it out last time the dock was moved away from its normal position.· I wasn't even sure if I dug back far enough (toward the shore).· A depth finder alert would help me with that.
Post Edited (jeffjohnvol) : 7/21/2008 1:42:24 PM GMT
'Still some PropSTICK Kit bare PCBs left!
I wonder if it would be possible though to hack one of these:· http://www.amazon.com/Uniden-QT-206WHP-Digital-Adjustable-Transducer/dp/B0000AXS0G.·
Searider
Chris I.
I was hoping there was a way to take a $100 depthfinder, cut the transducer wire and figure out out to issue a pulse and read to get a value. I understand the principal the way the parallax unit works, I was hoping i could do something similar with a sonar transducer I could buy or even cut off of of a boat in a junkyard.
Post Edited (jeffjohnvol) : 7/24/2008 7:10:04 PM GMT
