HB-25 and reversal of direction
I am interested in using the HB-25 as I add motors to a system I am building. They will be used to control trolleys that move back and forth on a track in a continuous fashion, with a smooth change of direction.
If the motor is running in one direction and I send a command to run in the other direction, does the HB-25 handle all this internally upon receipt of the new command? I can see that this is a peak current situation but are there other issues?
Thanks in advance
Quitman
Thanks in advance
Quitman
if your current speed is 2000, and you change direction and speed to 500, the ramp rate is the increment rate to reach the desired speed, which is handled all on the HB-25.it's handled in the object so if your ramp rate is 50, the HB-25 speed drops by 50 until it reaches the desired speed...... 2000, 1950, 1900, 1850....down to 500. I don't know the time interval between changes but it is quick.
added
sorry, I forget that not every one is using the propeller.
hope that helps.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Post Edited (Dgswaner) : 8/1/2008 4:37:59 PM GMT
Chris Savage
Parallax Tech Support
Quitman
DGSwaner
Post Edited (Dgswaner) : 8/6/2008 6:46:40 PM GMT
Chris Savage
