Centronics Parallel?
Oldbitcollector (Jeff)
Has anyone done a Centronics compatible parallel printer interface
with the Propeller yet?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
OBC
OBC
Centronix Pararel is one half on Intel 8255 IO Port.
It is on forum how interface it tu Propeller.
It neds only Centronix protokol programing.
Sapieha
Attached is some code I wrote 5 years ago for PICs (it uses a basic variant simliar to the PBasic/SXB). The code worked great on an older epson dot matrix printer I had laying around.
The only thing I don't understand how to translate is how to convert an ASCII code to binary across
P0-P7 If someone can show me an example I'd appreciate it. Looks like an EPSON driver for
the prop is in order...
OBC
Two years of playing with this thing and there is still much to learn...
Figures it was a one word command...
OBC
I never noticed that! I guess it just worked so I never noticed that mistake. The printer probably just moved the head back to the beginning of the line twice. No harm done, just makes it slightly slower I guess.
Oldbitcollector,
Yea, I forget how simple things are sometimes too. SPIN just has so many little things that can be easily forgotten.
Post Edited (Harrison.) : 8/1/2008 2:57:25 AM GMT
