BS2pe OEM off a 3.3V supply?
Hi,
Is it possible to run the BS2pe OEM off a 3.3V supply?
I have been looking at the SX48 chip spec sheet at it seems to run off 3.3V as does the EEPROM chip.· Is there any reason why this is not possible?
Cheers
Helen
Cheers
Helen
The BS2pe MOBO could run from 3.3V, however the BASIC Stamp Module version cannot. While the SX chip used is capable of this, the firmware is set to detect brownout at 4.2V, causing a reset below that voltage. I hope this helps. Take care.
Chris Savage
Parallax Tech Support
Thanks very much for the quick reply.· I thought that there must be a reason.· Is it possible to get a version with the firmware brown out changed to say 3V?
Cheers
Helen
Chris Savage
Since I thought "the interpreter code" was the most jealously guarded Parallax secret -- only available in an "OEM" chip pre-programmed by Parallax, with the "hide" fuse set.
A more likely scenario (it seems to me) would be to request Parallax to create some OEM chips with the lower brown-out setting. I wonder how many they'd have to sell to make it financially worth it? Do they program OEM chips one-by-one now?
Tracy Allen
www.emesystems.com
I guess that was a loaded response and I took for granted that not everyone noticed or knows of the current changes in the modules. The brownout detector on the BS2 has always been external. For consistency and to ensure extended temperature range considerations, the brownout detector has been moved external on all other models of BASIC Stamp as well. This means the firmware does not dictate the brownout setting. As I was getting at earlier though, you need to be sure that the voltage change doesn’t affect anything else such as timing of the EEPROM, etc. I think it is also possible for the resonator drive to be somewhat affected. This may only affect the temperature range that the device will operate in, however since it is done on the MOBO there is one example.
Chris Savage
A couple of years ago I found that the problem with low temperature operation on the SX based Stamps could be traced to the brownout detector, and specifically to the BOR42 setting. The BOR26 setting does not exhibit the problem, so the MOBO should be quite safe. I did extensive testing in an LCO2 chamber using both Stamps and SX chips at that time to evaluate and resolve this problem. Also asked John Barrowman and Jeff and Chip for help. With the BOR26 setting, it works down to -65 degC (limit of chamber). I have to assure operation of my OWL2pe to -40 degC for some customers.
For general information, the problem with the BOR42 happens at somewhere with chip to chip variation in the neighborhood of -5 to -25 degC. There is an interaction with the clock setting, so the problem is less pronounced on the BS2p, but it still happens, at a lower temperature bracket. It is not a matter of the clock oscillator stopping or failing to start. The chip just goes off into never-never land and stops executing code. I think Parallax is playing it safe, and making for consistency and opening up 3.3 volt possibilities for others by using the external brownout. They now have a very nice environmental chamber on site for testing, and I see that more of the modules are being advertised for extended temperature operation. I think Chip made a very careful design of the brownout detector for the Propeller.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 7/31/2008 8:18:48 PM GMT
Chris Savage
And thanks, Tracy, for the extra details. Your tests with the BOR26 setting are certainly reassuring!
'Still some PropSTICK Kit bare PCBs left!
Robert
